Boot Help: White VGA LED on B550 Mobo.
sirprinceington
33
PC Spec:
Ryzen 3600
ASUS TUF B550 plus
3060ti
A white VGA LED appeared this morning on boot. The PC fails to output to the monitors, with the fans, cpu cooler and RGB LEDs turning on as per usual.
I perused around for solutions but none seem to work. I have tried reseating the GPU and booting (failed). Booting without a GPU fails to output as well. Mind you the white light is constant during my attempts to troubleshoot.
That is to be expected as your CPU does not have ondie video so you will not get video from any of the MBs video ports.
In addition to the PSU info requested by Peter can you post the brand and model name or number of the RAM and how many sticks of it you have.
