Audio playing and recording issues with drivers
andrewgersh
22
I ended up having to reset my PC due to the fact that the audio drivers were messed up and i couldn't hear volume nor could i use my microphone. When I reset my PC, the drivers and microphone were working fine until i tried to join a Discord voice chat: when I joined, my newly built PC started running really slow, and my drivers got messed up again. Then I went ahead and uninstalled the audio drivers again and restarted my PC and they work again. I am new to the PC world and am just utterly confused on what is causing the issue, and at a loss at what I should do. Let me know if you would like any more information, i would gladly supply it. Thanks.
Hi @andrewgersh and welcome to PCHF :)
Flush DNS
Report IE Proxy Settings
Reset IE Proxy Settings
Report FF Proxy Settings
Reset FF Proxy Settings
List content of Hosts
List IP Configuration
List Winsock Entries
List Installed Programs
List Devices (Only Problems)
Ran by andre (administrator) on 28-08-2018 at 00:29:07
Running from "C:\Users\andre\Downloads"
Model: MS-7B48 Manufacturer: Micro-Star International Co., Ltd.
Boot Mode: Normal
Windows IP Configuration
Proxy is not enabled.
No Proxy Server is set.
Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter = Wi-Fi (Connected)
Realtek PCIe GBE Family Controller = Ethernet (Media disconnected)
Bluetooth Device (Personal Area Network) = Bluetooth Network Connection (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global
set interface interface="Ethernet (Kernel Debugger)" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Ethernet" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Wi-Fi" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Bluetooth Network Connection" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 2" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
set interface interface="Local Area Connection* 3" forwarding=enabled advertise=enabled nud=enabled ignoredefaultroutes=disabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : DESKTOP-ARHQIHP
Ethernet adapter Ethernet:
Physical Address. . . . . . . . . : 30-9C-23-B4-90-05
Wireless LAN adapter Local Area Connection* 2:
Physical Address. . . . . . . . . : EA-4E-06-5B-D8-26
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : E8-4E-06-5B-D8-26
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter
Link-local IPv6 Address . . . . . : fe80::79cc:f69f:134d:4fde%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.126(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, August 28, 2018 12:14:20 AM
Lease Expires . . . . . . . . . . : Wednesday, August 29, 2018 12:14:19 AM
DHCPv6 IAID . . . . . . . . . . . : 199773702
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-15-0C-82-30-9C-23-B4-90-05
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-1A-7D-DA-71-13
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 192.168.1.1
Addresses: 2607:f8b0:4009:811::200e
172.217.6.14
Pinging google.com [172.217.6.14] with 32 bytes of data:
Reply from 172.217.6.14: bytes=32 time=25ms TTL=55
Reply from 172.217.6.14: bytes=32 time=31ms TTL=55
Ping statistics for 172.217.6.14:
Minimum = 25ms, Maximum = 31ms, Average = 28ms
Server: Cisco02956
Addresses: 2001:4998:44:41d::3
2001:4998:44:41d::4
2001:4998:c:1023::4
2001:4998:c:1023::5
2001:4998:58:1836::11
2001:4998:58:1836::10
98.138.219.232
72.30.35.9
98.138.219.231
98.137.246.8
72.30.35.10
98.137.246.7
Pinging yahoo.com [98.137.246.7] with 32 bytes of data:
Reply from 98.137.246.7: bytes=32 time=86ms TTL=53
Reply from 98.137.246.7: bytes=32 time=100ms TTL=53
Ping statistics for 98.137.246.7:
Minimum = 86ms, Maximum = 100ms, Average = 93ms
Interface List
4...30 9c 23 b4 90 05 ......Realtek PCIe GBE Family Controller
7...ea 4e 06 5b d8 26 ......Microsoft Wi-Fi Direct Virtual Adapter
8...e8 4e 06 5b d8 26 ......Microsoft Wi-Fi Direct Virtual Adapter #2
17...e8 4e 06 5b d8 26 ......Realtek RTL8811AU Wireless LAN 802.11ac USB 2.0 Network Adapter
3...00 1a 7d da 71 13 ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.126 55
192.168.1.0 255.255.255.0 On-link 192.168.1.126 311
192.168.1.126 255.255.255.255 On-link 192.168.1.126 311
192.168.1.255 255.255.255.255 On-link 192.168.1.126 311
224.0.0.0 240.0.0.0 On-link 192.168.1.126 311
255.255.255.255 255.255.255.255 On-link 192.168.1.126 311
Persistent Routes:
None
IPv6 Route Table
Active Routes:
1 331 ::1/128 On-link
17 311 fe80::/64 On-link
17 311 fe80::79cc:f69f:134d:4fde/128
On-link
1 331 ff00::/8 On-link
17 311 ff00::/8 On-link
Persistent Routes:
None
Catalog5 01 C:\WINDOWS\SysWOW64\napinsp.dll [54784] (Microsoft Corporation)
Catalog5 02 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 03 C:\WINDOWS\SysWOW64\pnrpnsp.dll [70656] (Microsoft Corporation)
Catalog5 04 C:\WINDOWS\SysWOW64\NLAapi.dll [64000] (Microsoft Corporation)
Catalog5 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog5 06 C:\WINDOWS\SysWOW64\winrnr.dll [24064] (Microsoft Corporation)
Catalog5 07 C:\WINDOWS\SysWOW64\wshbth.dll [51712] (Microsoft Corporation)
Catalog9 01 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 02 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 03 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 04 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 05 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 06 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 07 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 08 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 09 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 10 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 11 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 12 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 13 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
Catalog9 14 C:\WINDOWS\SysWOW64\mswsock.dll [341920] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\napinsp.dll [67072] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [84992] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\NLAapi.dll [80896] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [31232] (Microsoft Corporation)
x64-Catalog5 07 C:\Windows\System32\wshbth.dll [63488] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 11 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 12 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 13 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
x64-Catalog9 14 C:\Windows\System32\mswsock.dll [401968] (Microsoft Corporation)
Application errors:
Error: (08/28/2018 12:14:21 AM) (Source: Software Protection Platform Service) (User: )
Description: License Activation (slui.exe) failed with the following error code:
hr=0x803F7001
Command-line arguments:
RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=NetworkAvailable
Error: (08/28/2018 12:14:16 AM) (Source: Software Protection Platform Service) (User: )
hr=0x80072EE7
RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (08/28/2018 12:13:03 AM) (Source: Application Hang) (User: )
Description: The program SystemSettings.exe version 10.0.17134.112 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 23a0
Start Time: 01d43e855cb73c71
Termination Time: 4294967295
Application Path: C:\Windows\ImmersiveControlPanel\SystemSettings.exe
Report Id: c6d097de-9303-4fa9-b007-408f1f207c12
Faulting package full name: windows.immersivecontrolpanel_10.0.2.1000_neutral_neutral_cw5n1h2txyewy
Faulting package-relative application ID: microsoft.windows.immersivecontrolpanel
Error: (08/28/2018 12:12:01 AM) (Source: Software Protection Platform Service) (User: )
hr=0x803F7001
hr=0x803F7001
Error: (08/28/2018 12:10:07 AM) (Source: Application Hang) (User: )
Description: The program svchost.exe version 10.0.17134.1 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: a80
Start Time: 01d43e72f8f4a70b
Termination Time: 0
Application Path: C:\Windows\System32\svchost.exe
Report Id: 0106a752-bb1a-4b5b-8b2b-b15979724492
Error: (08/28/2018 12:09:56 AM) (Source: Application Hang) (User: )
Process ID: 19bc
Start Time: 01d43e84e9381896
Report Id: a49f5564-81c1-41a9-9cd2-b8764c2f506a
Error: (08/28/2018 12:09:26 AM) (Source: Application Hang) (User: )
Process ID: 24cc
Start Time: 01d43e84afa73c00
Report Id: fe1df50d-a17e-4b40-9fe2-ae2e218a550c
Error: (08/28/2018 12:08:55 AM) (Source: Application Hang) (User: )
Process ID: a80
Report Id: 4e9ce243-11da-4f20-96b5-f94b610b7c5f
Error: (08/27/2018 11:55:57 PM) (Source: Software Protection Platform Service) (User: )
hr=0x803F7001
System errors:
Error: (08/28/2018 12:16:05 AM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalLaunchWindows.SecurityCenter.WscDataProtectionUnavailableNT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Description: application-specificLocalLaunchWindows.SecurityCenter.WscBrokerManagerUnavailableNT AUTHORITYSYSTEMS-1-5-18LocalHost (Using LRPC)UnavailableUnavailable
Error: (08/28/2018 12:14:41 AM) (Source: DCOM) (User: DESKTOP-ARHQIHP)
Description: application-specificLocalLaunchWindows.SecurityCenter.WscCloudBackupProviderUnavailableDESKTOP-ARHQIHPandreS-1-5-21-2834899404-4135191748-544439242-1001LocalHost (Using LRPC)UnavailableUnavailable
Error: (08/28/2018 12:14:36 AM) (Source: DCOM) (User: DESKTOP-ARHQIHP)
Description: application-specificLocalActivation{D63B10C5-BB46-4990-A94F-E40B9D520160}{9CA88EE3-ACB7-47C8-AFC4-AB702511C276}DESKTOP-ARHQIHPandreS-1-5-21-2834899404-4135191748-544439242-1001LocalHost (Using LRPC)UnavailableUnavailable
Error: (08/28/2018 12:14:25 AM) (Source: DCOM) (User: DESKTOP-ARHQIHP)
Error: (08/28/2018 12:14:11 AM) (Source: DCOM) (User: NT AUTHORITY)
Description: application-specificLocalActivation{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}NT AUTHORITYLOCAL SERVICES-1-5-19LocalHost (Using LRPC)UnavailableUnavailable
Error: (08/28/2018 12:14:00 AM) (Source: Microsoft-Windows-Kernel-Processor-Power) (User: NT AUTHORITY)
Description: Performance power management features on Hyper-V logical processor 5 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 4 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Description: Performance power management features on Hyper-V logical processor 3 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Microsoft Office Sessions:
Error: (08/28/2018 12:14:21 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x803F7001RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=NetworkAvailable
Error: (08/28/2018 12:14:16 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x80072EE7RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (08/28/2018 12:13:03 AM) (Source: Application Hang)(User: )
Description: SystemSettings.exe10.0.17134.11223a001d43e855cb73c714294967295C:\Windows\ImmersiveControlPanel\SystemSettings.exec6d097de-9303-4fa9-b007-408f1f207c12windows.immersivecontrolpanel_10.0.2.1000_neutral_neutral_cw5n1h2txyewymicrosoft.windows.immersivecontrolpanel
Error: (08/28/2018 12:12:01 AM) (Source: Software Protection Platform Service)(User: )
Description: hr=0x803F7001RuleId=31e71c49-8da7-4a2f-ad92-45d98a1c79ba;Action=AutoActivate;AppId=55c92734-d682-4d71-983e-d6ec3f16059f;SkuId=2b1f36bb-c1cd-4306-bf5c-a0367c2d97d8;NotificationInterval=1440;Trigger=UserLogon;SessionId=1
Error: (08/28/2018 12:10:07 AM) (Source: Application Hang)(User: )
Description: svchost.exe10.0.17134.1a8001d43e72f8f4a70b0C:\Windows\System32\svchost.exe0106a752-bb1a-4b5b-8b2b-b15979724492
Error: (08/28/2018 12:09:56 AM) (Source: Application Hang)(User: )
Description: SystemSettings.exe10.0.17134.11219bc01d43e84e93818964294967295C:\Windows\ImmersiveControlPanel\SystemSettings.exea49f5564-81c1-41a9-9cd2-b8764c2f506awindows.immersivecontrolpanel_10.0.2.1000_neutral_neutral_cw5n1h2txyewymicrosoft.windows.immersivecontrolpanel
Error: (08/28/2018 12:09:26 AM) (Source: Application Hang)(User: )
Description: SystemSettings.exe10.0.17134.11224cc01d43e84afa73c004294967295C:\Windows\ImmersiveControlPanel\SystemSettings.exefe1df50d-a17e-4b40-9fe2-ae2e218a550cwindows.immersivecontrolpanel_10.0.2.1000_neutral_neutral_cw5n1h2txyewymicrosoft.windows.immersivecontrolpanel
Error: (08/28/2018 12:08:55 AM) (Source: Application Hang)(User: )
Description: svchost.exe10.0.17134.1a8001d43e72f8f4a70b4294967295C:\Windows\System32\svchost.exe4e9ce243-11da-4f20-96b5-f94b610b7c5f
Error: (08/27/2018 11:55:57 PM) (Source: Software Protection Platform Service)(User: )
Car Mechanic Simulator 2014 (HKLM\...\Steam App 270850) (Version: - PlayWay S.A.)
Counter-Strike: Global Offensive (HKLM\...\Steam App 730) (Version: - Valve)
Discord (HKCU\...\Discord) (Version: 0.0.301 - Discord Inc.)
DisplayDriverAnalyzer (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_DisplayDriverAnalyzer) (Version: 399.07 - NVIDIA Corporation) Hidden
Epic Games Launcher (HKLM-x32\...\{E7B62E3F-0F70-4119-89A2-28DE1C3873CC}) (Version: 1.1.163.0 - Epic Games, Inc.)
Epic Games Launcher Prerequisites (x64) (HKLM\...\{66C5838F-B854-4A55-89E6-A6138747A4DF}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 68.0.3440.106 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.33.17 - Google Inc.) Hidden
Hi-Rez Studios Authenticate and Update Service (HKLM-x32\...\{3C87E0FF-BC0A-4F5E-951B-68DC3F8DF1FC}) (Version: 3.0.0.0 - Hi-Rez Studios)
Launcher Prerequisites (x64) (HKLM-x32\...\{c6c5a357-c7ca-4a5f-9789-3bb1af579253}) (Version: 1.0.0.0 - Epic Games, Inc.) Hidden
Logitech G HUB (HKLM\...\{521c89be-637f-4274-a840-baaf7460c2b2}) (Version: - Logitech, Inc.)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 18.151.0729.0005 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x64) - 14.10.25008 (HKLM-x32\...\{f1e7e313-06df-4c56-96a9-99fdfd149c51}) (Version: 14.10.25008.0 - Microsoft Corporation)
Microsoft Visual C++ 2017 Redistributable (x86) - 14.10.25008 (HKLM-x32\...\{c239cea1-d49e-4e16-8e87-8c055765f7ec}) (Version: 14.10.25008.0 - Microsoft Corporation)
NVIDIA 3D Vision Controller Driver 390.41 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 390.41 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 399.07 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 399.07 - NVIDIA Corporation)
NVIDIA GeForce Experience 3.14.1.48 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 3.14.1.48 - NVIDIA Corporation)
NVIDIA Graphics Driver 399.07 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 399.07 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.37.4 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.37.4 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.17.0524 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.17.0524 - NVIDIA Corporation)
PunkBuster Services (HKLM-x32\...\PunkBusterSvc) (Version: 0.994 - Even Balance, Inc.)
SMITE (HKLM\...\Steam App 386360) (Version: - Hi-Rez Studios)
Twitch (HKCU\...\{DEE70742-F4E9-44CA-B2B9-EE95DCF37295}) (Version: 7.0.0.0 - Twitch Interactive, Inc.)
Percentage of memory in use: 43%
Total physical RAM: 8152.73 MB
Available physical RAM: 4595.71 MB
Total Virtual: 10072.73 MB
Available Virtual: 4638.92 MB
1 Drive c: () (Fixed) (Total:465.16 GB) (Free:382.52 GB) NTFS
2 Drive g: (Game HDD) (Fixed) (Total:1863 GB) (Free:1435.87 GB) NTFS
User accounts for \\DESKTOP-ARHQIHP
Administrator andre DefaultAccount
Guest WDAGUtilityAccount
**** End of log ****
Let's see if the correct drivers are installed.
  • Download Unknown Device Identifier v9.00
  • Run it.
  • Allow it to complete.
  • Hit File >>Save
  • The default name will be DeviceList
  • Save it to your desktop.
  • Open DeviceList.txt copy contents.
  • Paste it here.
