Solved A couple of issues I am hoping for some help with
Better picture.
Ok download both drivers only one will work. Look at my pic for settings that should work for your machine
Will do. It will take me a minute. I left my thumbdrive at work so I will need to use cd-r or DVD, so i am going to download all the possible drivers.
Have them transferred to xp computer now. Everyone I click gives me the same win32 error
Odd you did choose XP and not XP 64 bit.
That message normally means 64 instead of 32 or corrupt driver. is it an exe file or a zip file.
If zip then it has to unpack first.
I don't want you to keep wasting dvd's
Try this
If it has a yellow mark and no name then right click on the adapter>Left click on Properties >Details Tab.
Use the drop down box to show Device Description. If no name change the drop down to Hardware Id's
What is listed?
To clarify, I actually did choose 64 bit because I failed to express that the version of Windows I have installed is xp 64 bit pro. And I did choose the dell drivers for 64 (although I originally linked you to 32 bit)
Here is what it shows.
I think I may know part of my problem and I apologize for wasting your time. I wasn't even thinking when I installed this WinXP and it being a 64 bit OS. The PC is a 32 bit system. I am going to uninstall XP and see if I can find a 32 bit version.
I don't know man. I am reading somethings that say you can't install a 64 bit OS on a 32 bit system. However, this windows is 64 bit and the system information for the PC shows me an x86 which I thought meant 32 bit. I am about ready to give up. This is becoming more trouble than it is worth.
Others
I installed xp 32 bit. but I will say that I found a service tag on this PC and was able to look it up on Dell's site. I found the exact drivers I need from them but again, they are all in exe form and when I try to execute them I get the win32 error.
Can you open a command / Dos Prompt and type sfc /scannow press enter NB there is a space between sfc and the slash
IF that runs when finished at the dos prompt chkdsk C: /f /r press enter
The first appeared to run correctly and finished. No command prompt came up so I brought one up and typed in what you said and it said path not found
Nevermind, I forgot to put in chkdsk, but it says it cant run because it is in use. I am going to try to restart it
