Solved A corruption was found in a file system index structure. The file reference number is 0x30000000212ea.
C:\FRST\Quarantine\C\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR
C:\FRST\Quarantine\C\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\WinRAR help.lnk
C:\FRST\Quarantine\C\ProgramData\Microsoft\Windows\Start Menu\Programs\WinRAR\WinRAR.lnk
i still get these on void tools is this okay?
They are in quarantine. So not active on your system. Is there anything else you need help with?
Ok, let's check a little deeper since you are here.
Adware Cleaner
  • Download AdwCleaner and save it to your Desktop
  • Right-click on AdwCleaner.exeand select, Run as Administrator
  • Accept the EULA (I accept), then click on Scan Now
  • Let the scan complete
  • Once the scan completes, make sure that every item listed in the different tabs is checked and click on the Quarantine and delete.
  • Once the cleaning process is complete, AdwCleaner will ask you to restart your computer
  • Close all other open windows and allow it to restart
  • After the restart, Notepad will open with the AdwCleaner cleaning log
  • Please Attach the contents of that log into your next reply to me
Download Malwarebytes v.4 . Install and run.
  • Once the MBAM dashboard opens, click on Settings (gear icon).
  • Click on Security tab and make sure that all four Scan options are enabled.
  • Close Settings and click on the Scan button on the dashboard.
  • Once the scan is completed make sure you have it quarantine any detections it finds.
  • If no detections were found click on the Save results drop-down, then the Export to TXT button and save the file as a Text file to your desktop.
  • If there were detections then once the quarantine has completed click on the View report button, then click the Export drop-down, then the Export to TXT button, and save the file as a Text file to your desktop or other location you can find and attach that log on your next reply.
  • If the computer restarted to quarantine you can access the logs from the Detection History, then the History tab. Highlight the most recent scan and double-click to open it. Then click the Export drop-down, then the Export to TXT button, and save the file as a Text file to your desktop or other location you can find and include that log on your next reply.
Ok. Let's do this.
This fix will take some time, do not stop it when it starts. Just allow completion!!
Copy the content of the code box below.
Do not copy the word code!!!
Right Click FRST and run as Administrator.
Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
Attach it to your next message.
Code:
Start::
CloseProcesses:
SystemRestore: On
CreateRestorePoint:
StartBatch:
  ECHO Y|CHKDSK C: /F /R
  pushd c:\windows\system32
  bcdedit.exe /set {default} recoveryenabled yes
  net stop bits
  net stop cryptSvc
  net stop wuauserv
  net stop msiserver
  del /s /q C:\Windows\SoftwareDistribution\download\*.*
  del /s /q "%userprofile%\AppData\Local\Google\Chrome\User Data\Default\Cache\*.*"
  del /s /q "%userprofile%\AppData\Local\Microsoft\Edge\User Data\Default\Cache\*.*"
  del /s /q "%userprofile%\AppData\Local\Opera Software\Opera Stable\Cache\Cache_Data\*.*"
  netsh winsock reset catalog
  netsh int ipv4 reset reset.log
  netsh int ipv6 reset reset.log
  ipconfig /release
  ipconfig /renew
  ipconfig /flushdns
  ipconfig /registerdns
  net start bfe
  net start bits
  net start cryptSvc
  net start eventsystem
  net start msiserver
  net start rpcss
  net start sdrsvc
  net start trustedinstaller
  net start vss
  net start winmgmt
  net start wuauserv
  bitsadmin /list /allusers
  bitsadmin /reset /allusers
EndBatch:
cmd: fsutil resource setautoreset true c:\&fsutil usn deletejournal /d /n c:
cmd: DISM.exe /Online /Cleanup-image /Restorehealth
cmd: sfc /scannow
cmd: winmgmt /salvagerepository
cmd: winmgmt /verifyrepository
cmd: "%WINDIR%\SYSTEM32\lodctr.exe" /R
cmd: "%WINDIR%\SysWOW64\lodctr.exe" /R
EmptyTemp:
Reboot:
End::
Reboot the machine again and see if the scanning drive error is still there.
First, create a restore point. To do this, open an elevated command prompt, copy each line into the code field below, and press Enter.
Code:
wmic /Namespace:\\root\default Path SystemRestore Call Enable "%SystemDrive%"
WMIC /Namespace:\\root\default Path SystemRestore Call CreateRestorePoint "pchelpforum", 100, 10
Note. It is very important to run this tool only in safe mode!
Download Windows all in one recovery tool.
Install the program.
Load windows in safe mode.
Right-click all in one recovery tool and run as administrator.
Run it with all the default items checked.
Let it finish, and once it's done, boot up normally and check for the problem.
Reactions: Marco Oliveras
