Solved 5700 xt 99 degrees celsius
Cold Hands
3
24
Hello, I've bought a new 5700xt a few month ago. Everything was going fine until today, usually in monster hunter wilds temprature was about 75 degrees but today my gpu started overheating to 99 degrees and somehow I feel like rpm in my gpu is rly low while compared to what internet says. Does anyone know how to fix it? I have tried to install different drivers from 25.3.1 to 24.12.1. Also used DDU to clear drivers to 0 and install them, used afterburner while trying to make rpm to go faster and it didnt change a thing
my specs are:
rx 5700 xt
i3-12100f
32ddr4 gb ram
MSI PRO H610M-B DDR4 (s1700, Inter H610)
Can you Download and run and then post.​
In Speccy, click File, and then click Publish Snapshot.​
  1. In the Publish Snapshot dialog box, click Yes to enable Speccy to proceed.
  2. Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
The last part of each URL is randomized, so only people you provide with the URL will be able to find your profile.
The information given in Speccy cannot be used by anyone to hack your system
*** Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w ***
Im sorry for taking your time, I dissasembled my gpu and one of the cooler pins is yellow. I guess it got burned and whenever rpm tried to go over 60-70% it just dropeed to a minimum
