I7-14700k idle temp at 50-60 °C gaming temp default 80+°C max 95.0°C tested on Fortnite AIO Problem?
  • Samuha
    • Feb 2024
    • 9
    Just built a new pc and set up this aio cooler. I have the same one on my gf’s pc and it has no issues and runs with max gaming temp 80, normally just above 70 °C and idle on that pc is around 30-45 °C (Cpu on that one is Intel Core i5-12600K). Weird that on this pc the same aio is not working right. What is the issue on this? Do i have it plugged onto the wrong place or something? Or does my CPU require better cooling?
    I connected the case fans in chain like each to each other (4x) and so on, they work fine and i can control them from the motherboard bios, no issues there.
    Then the AIO itself i plugged first into the CPU fan1 slot and then into the CPU fan2/wp and i could change in the bios that CPU fan2 to water pump and control that. Temps are still high. AIO fans i set them in bios to go with the cpu temp, i hear the fans speeding up, speeding down constantly. I have no clue what is the issue here. Need help.
    Specs:
    [HEADING=2]Fractal Design Pop XL Air RGB Black - TG Clear Tint[/HEADING]
    [HEADING=2]ASRock Z690 Phantom Gaming 4 Motherboard DDR4[/HEADING]
    [HEADING=2]Intel Core i7-14700K Raptor Lake-S[/HEADING]
    [HEADING=2]Cooler Master MWE Gold V2 Full Modular 750W[/HEADING]
    [HEADING=2]Corsair Vengeance LPX DDR4-3600 - 16GB - CL18 - Dual Channel Intel XMP[/HEADING]
    [HEADING=2]Lexar NM620 SSD - 2TB - M.2 2280 - PCIe 3.0[/HEADING]
    [HEADING=2]ASUS GeForce RTX 4060 Ti DUAL OC - 8GB GDDR6 RAM[/HEADING]
    [HEADING=2]Aerocool Mirage L240, 240mm AIO[/HEADING]
  • Samuha
    • Feb 2024
    • 9
    [ATTACH type=“full”]13409[/ATTACH]HWMonitor Currently.
      download and post Speccy - Free Download
      To post.
      • Samuha
        • Feb 2024
        • 9
        http://speccy.piriform.com/results/h...tlpNX5ni2vZny3 There.
          Thanks
          @Pyro @PeterOz
          • Pyro
            • Jan 2019
            • 1189
            Is this the cooler you have?
            [ATTACH type=“full” width=“524px”]13410[/ATTACH]
            A few things I noticed:
            1. You have AVG Antivirus installed, one of our senior member has a whole list on reasons why this is bad, but the short of it is that Windows Defender is adequate for 90% of people + it doesn’t gunk up your Windows load.
            2. You have the power plan set to high performance, this is a form of overclocking and can cause instabilities/overheating, we only recommend this for gaming laptops where they need the extra power.
            3. Windows was installed within the last 24 hours, but it looks like drivers were neglected, the installation should go as follows- Windows, Chipset, Sata/Storage, Graphics, any others, Windows updates. It is critical that the PC is not connected to internet before the drivers are loaded, otherwise Windows will load basic drivers which are not the best for performance machines.
            • Samuha
              • Feb 2024
              • 9
              [ATTACH]13410[/ATTACH]
              Removed AVG, i can see that.
              Set the power plan to balanced.
              I installed latest bios update from asrock website and used usb to usb flashback when i built this pc, also when i launched this pc and got past windows install, asrock popped up after login and asked to install some driver updater thing and it downloaded some drivers, Realtek audiodrivers etc. Do i need more drivers? And how? Cant find that ssd driver anywhere.
              Also set the PUMP to run at 100% in bios, it seems to have helped a bit, getting a small decrease in temperature.
              Sorry i am not the best at this.
              [ATTACH type=“full” alt=“1708615290252.png”]13412[/ATTACH]
              This is the one im using.
              • PeterOz
                PCHF Technical Response Team
                • Mar 2021
                • 4181
                To confirm you have plugged the aio into No.6 .
                [ATTACH type=“full”]13415[/ATTACH]
                Drivers https://pg.asrock.com/mb/Intel/Z690%...x.asp#Download
                • Samuha
                  • Feb 2024
                  • 9
                  [ATTACH type=“full” alt=“Asrock aio connection.png”]13415[/ATTACH]
                  Drivers https://pg.asrock.com/mb/Intel/Z690 Phantom Gaming 4/index.asp#Download
                  Yes.
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #10
                    What thermal paste did you use?
                    Did you put just a thin layer of paste?
                    • PeterOz
                      • Mar 2021
                      • 4181
                      #11
                      Ok you have the pump connected to pin 6 which is correct.
                      Are the aio fans connected to connector 3 CPU_Fan 1?
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #12
                        Is the orientation of the pumps and the fans the same in both cases.
                        No undue bends in your pipes?
                        Are you overclocking the cpu?
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #13
                          This video that compares cpu’s suggest more cooling needed.(5mins 30sec into video).
                          The only way to tell if the aio has an issue is to swap it out with the other computer.
                          Good luck convincing you GF to allow that.
                          • Samuha
                            • Feb 2024
                            • 9
                            #14
                            Alphacool Silver Grease
                            Have used that before too. Works fine. And a decent layer. Not too thin not too much. Also repasted this 2 times. 1st installation used the thermal paste that came with the cooler.
                            Also the AIO Fans are connected to Chassis fan 4 if remember correctly.
                            One of the fans has a bit of a rattle. Small noise coming off it and its wobbling a little bit.
                            • PeterOz
                              • Mar 2021
                              • 4181
                              #15
                              Should be on No.3 for fans CPU-Fans 1
                              and the pump as you have No.6 CPU WP
