Pc does not post, showing no signal on monitor
    #16
    @XeroZen - any progress?
    • XeroZen
      • Dec 2023
      • 9
      #17
      Hi thanks for all the help and suggestions. You are right the gpu is the issue since at the time used the same cable. Guess it is no driver issue then. Is the gpu finished totally or maybe it could be repaired somehow. Is there any hope, or i have to change the gpu totally which i am not sure would want to do.
        #18
        Nine times out of ten it is not a financially viable option to repair internal hardware and the only way to find out what is wrong is to pay a local tech to check it out, be sure to ask what any charge will be before you commit to getting the card tested.
