Hi,
I am currently looking into purchasing a moderately priced gaming PC and ideally I would like to use the Kolink Void RGB Tempered Glass Case
due to the aesthetics, however the case only comes with 1 x rear fan included which has me worried that the system will run too hot if I don’t install extra fans so I had some questions for you guys about that and the parts I am hoping to put into it.
I am in Australia so I am planning to purchase from PC Case Gear using their customizable feature which gives me some limited choice over which parts to mix and match with the case.
The parts I am currently considering are:
[li]Intel Core i5 12600 Processor[/li][li]MSI MAG B660M Mortar Wi-Fi DDR4 Motherboard[/li][li]ASUS GeForce RTX 3060 KO Gaming LHR 12GB[/li][li]Team T-Force Delta RGB 16GB (2x8GB) 3200MHz CL16 DDR4[/li][li]Team Cardea Z44L M.2 PCIe Gen4 NVMe SSD 1TB[/li][li]Corsair RM650x Gold Modular 650W Power Supply V2[/li][li]Kolink Void RGB Tempered Glass Case Black[/li][/ul]
One option I am considering is to get a better CPU and Motherboard:
[li]Intel Core i7 12700 Processor[/li][li]ASUS ROG Strix B660-A Gaming Wi-Fi DDR4 Motherboard[/li][/ul]
So based on either of those specs do you recommend that I need to add additional fans? There is no option to have more fans installed as part of this template so I would have to do it myself after I get the PC. The case is advertised as having space for 3 x 120mm fans at the front and 2 x 120mm in the top. How difficult is it for someone with zero PC building experience to install extra fans?
Apart from case fans would I also need to consider a CPU cooler?
One final question I have is regarding the ASUS ROG Strix B660-A Motherboard paired with the Intel Core i7 12700 Processor. Would this be a suitable pairing for that processor regarding things like VRM?
