Hey there, you are basically my last hope as the support only suggested to RMA stuff I’ve asked this on another Forum, but no one could really help me.
Two problems:
When I shut down the PC wile leaving the PSU Button ON the pc will boot up without problems BUT when I shut down the PC AND switch the PSU to OFF it will boot for a second, RED light for CPU shows up on Mainboard (according to Manual RED = CPU), then immediately shuts down, fans stopping, and finally boots on without problems again.
Buzzing over Headphones only when plugged into the front panel.
FPS drops but only for 0,5 - 1 second and sometimes it even jumps up 1 fps resulting in stutter, too
I’ve had it on my old PC (which I’ve sent back and received the same again, so basically on 2 different systems [only the fps drops not the boot up problem)
H310M pro-m2 plus
i5 8600
GTX 1070
Noname 500w PSU - happened on both, the one I sent back and the replacement.
Then I’ve upgraded to the following
ROG Strix 390-E
I7 8700k
GTX 1070
Seasonic Focus 650W Platinum
What I tried:
	I’v also bought something to test the socket’s grounding, should arrive in an hour.
RAM and CPU are dropping from their max boost kinda fluctuating
Ram = from 1333 to 1332MHZ
CPU from 4400 MHZ to 4397MHZ (sometimes a bit more or less, for both RAM and CPU)
Should stay constant while ingame right?
The highest my CPU consumed inside a Game was 45w, most of the time it sits at ~30-35w while on turbo-boost
[MEDIA=imgur]a/p5Yowne[/MEDIA]
[MEDIA=imgur]a/0m7Hb4b[/MEDIA]
Pleas help me Guys
					Two problems:
H310M pro-m2 plus
i5 8600
GTX 1070
ROG Strix 390-E
I7 8700k
GTX 1070
What I tried:
Code:
	Watching Task Manager and Process-Explorer searching for demanding tasks Tried XMP and XMP1 Profile Watching temperatures (Just yesterday the Temps got even better, as I've put a case fan in, it was fine before, except for the psu getting high temp because of the hot air accumulating) - so no thermal throttling I did two userbenchmark tests (one on my old and one on this system) where everything was at least running as expected or above Disabling V-Sync - then I'll get more fps but strange enough : I'm still experiencing stutter on my 60hz tv when the fps drop from 100fps or higher to 95-97fps (I just don't get it) Tried different GPU drivers, from older ones to newest, installing them using DDU - nothing Moving Games from SSD to HDD Changing Nvidia Power Plan to Max Changing Powersaving option to high performance lowering graphis, setting high resolution and high settings to see if anything changes, but nope.
Pleas help me Guys
