Need Help Double Checking Parts List for my First Ever Build!
  • comp00tern00b
    • Jun 2018
    • 3
    I have spent a good bit of time working to get my own gaming pc and I have a build idea! I don’t have a great history when it comes to part compatibility so at this point I’m kinda superstitiously checking that everything should go smoothly once i manage to scrape together enough cash to purchase the parts. What I need is for someone experienced to check over everything I have listed and let me know if you notice anything that could cause issues. Like I said I have next to no experience so any advice or tips at all would be greatly appreciated. If you own a similar build, feel free to tell me about its performance, I know this won’t be any sort of 200fps beast, I’m just looking to get a fun experience with some games I’ve been itching to play
    Thanks a bunch!
    -me
    p.s if you think my choice in cpu seems odd, that’s because i already happen to own one and i designed the rest of the build around it.
    Gigabyte 78LMT-USB3 R2 (MB)
    AMD FX-4300 (CPU)
    Patriot Viper 3 Series 2x4gb (RAM)
    EVGA GeForce GT 1050 (GPU)
    WD blue 1tb hard drive (hard drive)
    EVGA 500 B1 (PSU)
    Corsair carbide 270R (case)
    • 8977
    I am sorry that link is not working correctly.. You can go here and fill in your want list and then it will tell you if all your choice are compatible..
    https://pcpartpicker.com
    When you go in select start your on parts build..
    • comp00tern00b
      • Jun 2018
      • 3
      Thanks, I’ll link the individual parts. (wasn’t sure if that link would work)
        • 15205
        Anu update comp00tern00b?
          • 8977
          Any updates for us? After 48 hrs this thread will be closed.
