Battery replacement for Nuu Mobile X5
This topic is closed.
  • Gs11
    • Jan 2020
    • 2
    Hi
    I’m looking for battery replacement for Nuu Mobile X5 do you know where can I find it? devicespecifications.com/en/model-battery/48064304
    I see on https://uk.nuumobile.com/ website that they have battery replacement for model X4, would it be compatible for model X5?
    Usually you can just match the model number of the battery and go from there,when ordering a replacement.
      Any updates?
      • Gs11
        • Jan 2020
        • 2
        still can’t find it
          I could only find a replacement X5 battery in India I`m afraid
          The X4 battery even if it would fit is too weak at 2250 mAh whereas the X5 battery is 2950 mAh.
