hi
i have a dell laptop running :
windows 11 home
64 bit
AMD Ryzen 3 3250U processor
in the last 2 days i have had 2 shutdowns unexpectantly . in event viewr it says the critical issue was a Kernel Power problem
i had the same problem about 18 months ago but nothing since then until this week .
the laptop is not overclocked
all power options are set to never and fast start up is disabled
the power cord is always plugged in and the battery is 100%
i ran sfc /scannow and CHKDSK , it did fix some issues but the problem still occurred
there is no file in the mini dump folder .
i have just updated the graphics driver .
i would appreciate any help . thanks very much
windows 11 home
64 bit
| + | System |
| - | EventData |
| BugcheckCode | 0 |
| BugcheckParameter1 | 0x0 |
| BugcheckParameter2 | 0x0 |
| BugcheckParameter3 | 0x0 |
| BugcheckParameter4 | 0x0 |
| SleepInProgress | 0 |
| PowerButtonTimestamp | 0 |
| BootAppStatus | 0 |
| Checkpoint | 0 |
| ConnectedStandbyInProgress | false |
| SystemSleepTransitionsToOn | 0 |
| CsEntryScenarioInstanceId | 0 |
| BugcheckInfoFromEFI | false |
| CheckpointStatus | 0 |
| CsEntryScenarioInstanceIdV2 | 0 |
| LongPowerButtonPressDetected | false |
