How to avoid having to Power Reset a battery
  • jrobb
    • Jan 2018
    • 19
    I cannot power on my Acer E5 unless I do a โ€œPower Resetโ€ first.
    If I remove the battery and A/C adapter then hold down the power button for 30 seconds, my laptop will turn on. When I turn it off, I can turn it back on within 15 minutes with no problem. After 15 minutes, I must do a power reset again.
    I recently replaced the battery and it charges and holds a charge properly. The power LEDโ€™s do not light up when the A/C is connected except after I do the power reset. Then they work fine until I turn off the laptop. I have read posts that suggest that this is caused by static electricity build up but I donโ€™t know how to prevent it. Can someone tell me how to fix this?
  • DOUGIE
    • Jun 2017
    • 424
    Hi Jim. Welcome to PCHF.
    Looking here, you have had this issue for some time.
    How to avoid having to Power Reset my laptop each time I use it - Super User
    You never had this issue before replacing the Battery.
    I am guessing you have bought the wrong battery for your Laptop.
    Double check again you have the exact battery installed.
    • jrobb
      • Jan 2018
      • 19
      Hi Doug Thanks for responding.
      Let me clarify a little. Originally, I did not have this problem. But I had problems with the old battery. It would not charge and I noticed that the A/C LED would stay on after I unplugged the adapter. So I replaced the battery with a new one. After installing a new battery this problem began. The new battery was damaged when I received it so I had to get a 3rd battery (from a different source). But the problem continues. Again the battery functions properly. Itโ€™s just that the battery nor the A/C adapter will start the laptop unless I do a power reset. After it starts,everything works fine.
        Any updates for us?
        • jrobb
          • Jan 2018
          • 19
          No progress on this problem yet. I went to a computer repair shop and demonstrated the problem. The technician told me that he has never heard of anything like this.
          I am still hoping for some help.
          • jrobb
            • Jan 2018
            • 19
            Originally posted by vger
            Any updates for us?
            • jrobb
              • Jan 2018
              • 19
              I received a suggestion that I turnoff fast boot to solve the problem. I turned it off along with sleep and hibernate and my laptop now powers up normally. Thanks, for all the forum help.
                Thanks for the update. Iโ€™ll mark your thread as solved.
