Hi I got an i9 9900k and motherboard z370 and the pc randomly shut down I need unplug the main power for 15 sec to be able to boot again, I suspected first the gpu but I try another one got same problem, I think that the motherboard or psu, someone have and idea?
I9 9900k and Z370 problem
This topic is closed.
Was an okay unit years back but not for todays demanding - power hungry GPUs, it is so weak by today’s standards that it is rated as – Tier C • Low-end and is in fact obsolete.Originally posted by Geronimo9FSP raider 550 II,
Can we have the brand and model name or number of both GPUs.Originally posted by Geronimo9I suspected first the gpu but I try another one got same problem
Note that this is primarily an English speaking site so please only post in English and rather than immediately post again use the five minutes that you get to edit a previous post should you wish to add something.Comment
Bonjour à nouveau, j’écris effectivement en anglais mais mon téléphone ou mon navigateur traduit automatiquement dans ma langue d’origine ? Merci pour les précisions concernant le psu, puis pour les cartes graphiques j’ai testé avec RX580 8gb et rtx 1060 4gb et même problème avec les deux pour la config : Boitier :
275R NOIR
Processeur:
I9-9900K
Carte mère:
ASUS PRIME Z370-P
Carte graphique :
RX 580 ARMOR 8 Go OC
Carte graphique :
Pas de mise à niveau
BÉLIER:
CRUCIAL BALLISTIX 1X16GB PC 2666MHZ
BÉLIER:
Disque dur :
Disque SSD:
Carte graphique Samsung 970 EVO 250 Go M,2 NVME
Alimentation électrique :
FSP RAIDER II 550 - 80+Argent
Refroidissement :
COOLER MASTER 212 ÉDITION NOIRE
Merci encore pour votre aideComment
Originally posted by phillpower2Note that this is primarily an English speaking site so please only post in EnglishThere is no such a GPU.Originally posted by Geronimo9rtx 1060 4gbComment
Being that the OP revisited the forum but chose not to acknowledge my reply this thread will be closed.Comment
