As mentioned the dead GPU is most likely the result of it being used with an underpowered PSU, it is better when a GPU will just not work if the PSU rather than what most often happens which is the GPU will work but not to its maximum capability and all the time that the card is working it is being starved of power and as a result it is being made to work harder which overheats and weakens the card until it eventually breaks.
GPU cause Monitor to give no signal when stressing
b
Originally posted by phillpower2As mentioned the dead GPU is most likely the result of it being used with an underpowered PSU, it is better when a GPU will just not work if the PSU rather than what most often happens which is the GPU will work but not to its maximum capability and all the time that the card is working it is being starved of power and as a result it is being made to work harder which overheats and weakens the card until it eventually breaks.
imagine i have 750
say what u can help other than thatComment
Originally posted by MaRsHmeLOLcan u please skip the psu thing
Originally posted by MaRsHmeLOLimagine i have 750
Originally posted by MaRsHmeLOLsay what u can help other than thatComment
