PC not booting up need help
  • Saad
    • Jun 2024
    • 1
    I have a custom built PC specs are
    . i3 10100f
    . MSI h510m-b
    . Corsair ddr4 ram 16gb 3200mhz
    . RTX 2060
    . 650w mars gaming psu (MP 650-II)
    I built it myself a year ago for gaming it was working perfectly until yesterday when it randomly restarted while I was playing. Today I woke up and booted it up when it shut down on me after some time of use.it had never happened before ???. Now when I boot it up the display shows no signal and motherboard shows a red ez debug light (CPU). What should I do please help
    This may be a hardware issue.. This could be and psu issue.
      Complete junk, labelled as 650W but even when out of the box new the information label tells us that it can only produce 456W, the advertising label also states 85+ efficiency when there is no such an efficiency rating then looking at the specifications info it states there 80 PLUS No.
      Your GPU requires a minimum of a 500W or above Gold efficiency rated PSU from one of the following, Corsair, EVGA, Seasonic or Super Flower.
      Before making any purchase you need to see if you can borrow an appropriate PSU to swap in for testing purposes or alternatively get a local tech to test the rig for you, the present PSU is so bad that it may have already damaged one or more components.
        Being that the OP revisited the forum but chose not to reply this thread will be closed.
