RGB Fan hub question
  • bilbo_baggins
    • May 2024
    • 13
    I have an RGB fan hub ( the 5p rainbow controller)powering 4 RGB case fans . The hub is powered by a SATA cable, and isn’t plugged into the motherboard. But I noticed recently whilst replacing some internal parts that there is also a wire for Argb coming from the hub . How would I go about connecting this? My motherboard does have an argb port . Is it safe to plug this in while the hub is being powered by sata? At the moment the RGB is just controlled by remote
    We need your mobo spec’s .
    • bilbo_baggins
      • May 2024
      • 13
      The mb is an Asus prime b550m-a
        Is everything presently working as it should be.
        Is your fan hub the ASUS brand, if not and everything is working as it should be I would be inclined to leave well alone.
        • bilbo_baggins
          • May 2024
          • 13
          Everything is working . The fan hub isn’t Asus, it just says rainbow 5p on it . I can’t find a manual anywhere. As you’ve advised, I shall leave it be
            Wise decision and thanks for letting us know (y)
