VGA led light
  • Iamtoogood
    • May 2024
    • 1
    VGA led light
    Hey guys, I was wondering what is going on with my pc which I just finished building. When I boot it up the motherboard displays the red and yellow lights for 5 mins. Then after displays a white VGA led light. I can access the Bios by removing the CMOS battery and re-inserting it but I can’t boot up my pc with or without integrated graphics. I have a usb flash drive with windows 11 installed plugged into my motherboard. All of my graphics PCIE cables are plugged in that I am aware of tomorrow I will resit the CPU too see if this helps as I was also having the red led light pop up as well earlier.
    SPECS-
    Motherboard- MSI B650 Gaming Plus wifi
    CPU- Ryzen 7 7800X3D
    Gpu-Rtx 4070 Super
    Case-Montech Sky two
    RAM-Corsair vengance 32gb DDR5
    PSU-Corsair CV650
    SSD-P3 Crucial 1tb
    CPU Cooler-Deepcool Ak400
    That PSU is rated Tier C - Low End, see here; PSU Tier List rev. 17.0g - Cultists Network
    And at 650w is at the low end of the GPU needs.
    So a poor start from the get-go.
    What is the speed of your memory?
    Have you tried removing the Nvidia card and running on the onboard graphics?
      @Iamtoogood - any news?
        Abandone/closed.
