PC problems/ No keyboard lights, no post, no bios, etc
  • Diego_Ramirez
    • Mar 2024
    • 20
    #31
    Nevermind I was being dumb entering the wrong OPN for my CPU I made the claim so hopefully they’ll get back to me fast
    • Diego_Ramirez
      • Mar 2024
      • 20
      #32
      If that is the issue do you recommend getting a new CPU or is the issue just the BIOS?
      • PeterOz
        PCHF Technical Response Team
        • Mar 2021
        • 4181
        #33
        If that is the issue then no need for a new cpu.
        If You get a new cpu you could be in the same trouble.
        See what AMD say.
        • Diego_Ramirez
          • Mar 2024
          • 20
          #34
          So Im back after trying with AMD as trying to get the Boot kit or at lest some assistance but as I thought they won’t assist me as the cpu warranty has ran out and they won’t even get back to me so they just left me in the dust ???
          • PeterOz
            • Mar 2021
            • 4181
            #35
            Ask MSI or ask a local computer shop to borrow/rent an older cpu.
            It is the only thing I can think of what may be the cause.
            Have you contacted MSI?
            A new cpu could put you in the same spot.
            • Diego_Ramirez
              • Mar 2024
              • 20
              #36
              I have contacted them see when they’ll reply but I did some more things and such as just trying to find the problem so I have the cpu in the mobo with just the necessitys and no gpu and there’s still no power to the kbm is that normal because I can’t see the problem being the Mobo since I just bought it I can see the cpu as it’s old I’ll try to get a different cpu to test as the one I have is kinda old
              • PeterOz
                • Mar 2021
                • 4181
                #37
                If you get a new cpu and it does not match the bios you will have the same problem.
                @phillpower2 any suggestions?
                • Diego_Ramirez
                  • Mar 2024
                  • 20
                  #38
                  FINALLY, I ended up buying a new CPU because I had the money for it and I don’t see the wrong in buying so I but it in and the pc booted up finally so I think that was the problem the whole time
                    #39
                    That’s good news. (y)
                    I really don’t see many issues that are ‘bad’ CPU related.
                    Less than 6 I would reckon, including this one!
                    • Diego_Ramirez
                      • Mar 2024
                      • 20
                      #40
                      Well thank you guys Ik this was a long one but I greatly appreciate the help???
                        #41
                        Good result - will close as solved
