Post Upgrade low FPS and overall performance issues.
  • MadoX
    • Oct 2019
    • 36
    Hello brothers,
    i’ve recently upgraded my PC’s GPU and I am pretty unsatisfied with the results so far. My friend bought the old GPU off of me and in fact is having better performance than I am with my new one (his rig is almost identical to mine). We haven’t got any benchmarking software so we just used GTA 5’s in-built benchmark to check, i’m getting from 60-90FPS while he’s getting stable 120+FPS, also we were using the same settings and the same resolution 1920x1080.
    My specs:
    AMD Ryzen 5 3600 3.6GHz 6-Core
    AMD Radeon RX 6800 16GB (my old one was GTX 1080 8GB, the one my friend bought)
    2x 8GB 3200MHz sticks RAM
    Aorus elite v2 motherboard
    750W PSU (the only thing different in my friend’s rig is that he has 700W)
    I thank you for any answer and ideas I can get, because honestly I have no clue what’s going on. (Also i know about the HUGE bottleneck i have with the powerful GPU and weak CPU, I just didn’t have enough money to buy both at the same time, I just hope that that’s not what’s creating this whole issue.)
    Let’s get your complete PC specs.
    Get Speccy; Speccy - Download Builds
    In Speccy, click File > Publish Snapshot (hit Yes if prompted to proceed with publish) > Copy to Clipboard > Close.
    Now you can paste that link into your next post.
    List the make/model of the PSU. Just saying 750w PSU doesn’t let us know the efficiency rating, warranty or certification.
    Is Speccy safe?
    As to FPS drops, they are not my thing per say, as I’m not a gamer but here is my stock standard response, see if anything helps.
    If you have your PC as lean and clean as you can make it, that’s part of the battle.
    Sadly, the other parts may be outside your control like; number of users/devices on your network, bandwidth, line attenuation, signal to noise ratio, etc.
    Logging into your modem’s config menu will show these values.
    But things you can control are;
    [li]reboot modem/router/pc[/li][li]delete restore points[/li][li]turn off hibernation (powercfg -h off)[/li][li]empty web browser cache[/li][li]delete system temp files[/li][li]scan Windows for system corruption (sfc /scannow)[/li][li]scan drive for file corruption (chkdsk c: /r)[/li][li]disable unwanted scheduled tasks[/li][li]disable unnecessary startup services[/li][li]disable scheduled defragging[/li][li]TRIM any SSD’s[/li][li]turn off Timeline and Activity History, and all things Microsoft Telemetry based[/li][li]empty recycle bin[/li][li]delete log files and error reports[/li][li]remove old Windows Updates files[/li][li]cleanup software installer and distribution caches[/li][li]delete unwanted programs[/li][li]remove any browser extensions[/li][li]if connecting via wireless, try ethernet[/li][li]pause any online cloud storage synchronising (OneDrive, DropBox)[/li][/ul]
    CCleaner (free version) or Glary Disk Cleaner or the inbuilt cleanmgr command can do most of those points.
    ShutUp10 by O&O Software can stop a lot of telemetry items.
    Other things to try;
    [li]create another user account and login under that profile[/li][li]check for firmware updates for modem/router and PC BIOS[/li][/ul]
    Do a web speed check - go to www.speedtest.net and post the results.
    Have there been any changes in the time frame that the FPS rates have dropped?
    Like new software or hardware(apart from the new GPU), or extra users on the network?
    It could also be performance rot, and doing a fresh install of Windows may help.
    • MadoX
      • Oct 2019
      • 36
      Yes, firstly i’d like to appologize for the specs details or rather lack there of. I was generally ****** yesterday, just wanted to see what other people thought, maybe someone has encountered the problem before or something, i don’t really know. Here are my specs: http://speccy.piriform.com/results/y...DlOdX8Cdpueuq0
      I’d also like to go back to where I said i’ve had two 8GB 3200Mhz Ram sticks, and I did. But i suspected them to be faulty so I switched to one stick of 16GB i bought today. Yesterday I took the computer apart and looked for any faulty things, but the only thing i’ve noticed was that my case fan was not working at all. Wasn’t spinning yet the middle part of the fan was very hot. Not a great sign, is there a possibility that it could’ve shorted my motherboard or whatnot ?
      To go over the points you’ve shared:
      [li]reboot modem/router/pc[/li]-I’ve rebooted my pc/router,
      [li]delete restore points[/li]-Don’t have any as far as I know
      [li]turn off hibernation (powercfg -h off)[/li]-Typed the command into CMD
      [li]empty web browser cache[/li]-I didn’t do that since I don’t think that’s what’s harming my performance right now
      [li]delete system temp files[/li]-ran cleanmgr on all of my disks
      [li]scan Windows for system corruption (sfc /scannow)[/li]-Ran this command, this is the return message i got “Windows Resource Protection found corrupt files and successfully repaired them.”
      [li]scan drive for file corruption (chkdsk c: /r)[/li]-I got this return message when trying any of my disks “Chkdsk cannot run because the volume is in use by another
      process.” I didn’t try to get it to scan anyways right now.
      [li]disable unwanted scheduled tasks[/li]-I’ve looked through my tasks, most of these were for updates for software i use, disabled 2 or three that i didn’t use.
      [li]disable unnecessary startup services[/li]-Done
      [li]disable scheduled defragging[/li]-It was scheduled to Weekly, disabled scheduled defragging
      [li]TRIM any SSD’s[/li]-Done
      [li]turn off Timeline and Activity History, and all things Microsoft Telemetry based[/li]-Turned off activity history
      [li]empty recycle bin[/li]-Done
      [li]delete log files and error reports[/li]-Ran cleanmgr on all of my disks
      [li]remove old Windows Updates files[/li]-Ran cleanmgr on all of my disks
      [li]cleanup software installer and distribution caches[/li]-Went through my disks and got most of them I think.
      [li]delete unwanted programs[/li]-Done
      [li]remove any browser extensions[/li]-I have adblock plus and guardio installed, i don’t know if it does concern these extensions as well, let me know and I’ll get rid of them too.
      [li]if connecting via wireless, try ethernet[/li]-Done
      [li]pause any online cloud storage synchronising (OneDrive, DropBox)[/li]-Done when benchmarking, doesn’t show any noticeable difference in performance.
      [/ul]
      I also know that my BIOS is OLD, i’ve never updated it, it’s F1. I didn’t think it would be BIOS that’s harming my performance if that’s the case then also let me know.
      I’ve done the speedtest, results:
      Download: 818.91Mbps 11ms
      Upload: 117.34Mbps 27ms
      Ping: 2ms
      I’ve also reinstalled windows not so long ago, of course if that’s what hindering my performance i’ll do it again, but i’d like to leave as a kind of last resort.
      Also about the PSU it’s aero cool which I’ve heard nothing but negative comments towards. Ever since i’ve been looking into it more, i’m finding more and more problems with it. Not to mention I bought it with over 500€ markup price. Also the new RAM i bought was supposed to be 3600Mhz, I also checked the motherboard that it DOES support 3600Mhz yet when I check task manager it says the RAM speed is only 3200Mhz, I honestly have no clue what’s up with that either. Anyways, I hope i’ve been as thorough as I could’ve been, and didn’t miss anything.
      • MadoX
        • Oct 2019
        • 36
        A little update, im writing from my phone. Long story short i’ve been tinkering with the pc today with my friend, when we found literal molten plastic on my motherboard along with black stains. That confirms, that my motherboard is indeed fried, i’ll be installing a new one tomorrow along with new case fans, hopefully nothing else was damaged. So i guess i’ll be in touch when i get my pc up and running tomorrow.
          Good find with the mobo and while maybe not the cause, it would of course be the logical thing to replace at this stage.
          Hopefully, along with it and the case, you are replacing the power supply as well???
          As to the BIOS update, I would be doing that if you are comfortable, they aren’t that hard, you just need to be careful.
          Mobo manufactures often release updates to their firmware to support the latest GPU’s.
          But your new mobo should be pretty recent anyways.
          • MadoX
            • Oct 2019
            • 36
            I did update my bios before we found out the motherboard was fried. I didnt change the psu but i guess thats the last component i didnt change yet so it has be it.
              Sorry but I prefer to be straight and this set-up is as rough as they come
              They should ship with a fire extinguisher along with a public health warning, Aerocool did make a Platinum efficiency rated PSU years back that wasn`t too bad other than they had a nasty habit of tripping out, any other unit by them are rated between low end and replace immediately here
              Power Profile
              Active power scheme[COLOR=rgb(184, 49, 47)]: AMD Ryzen High Performance
              While we look at the Speccy report, one thing I will suggest is that you change the Windows Power Plan to Balanced, Ultra and High Performance are a form of overclocking that is known to cause stability and overheating issues and a weak PSU such as the one that you have will get hotter and weaker the more that you use it.
              Will finish going through Speccy and then get back to you, if you have not post since I will edit this reply.
              CPU
              AMD Ryzen 5 3600: 38 °C
              Matisse 7nm Technology
              RAM
              16,0GB Single-Channel DDR4 @ 1596MHz (16-20-20-38)
              [COLOR=rgb(184, 49, 47)]Part Number: KF3600C18D4/16GX
              You have wasted your cash on the 3600MHz RAM I`m afraid, it is not a problem at the moment because it can only work in single channel but if you were to add a matching stick and enable XMP the RAM will get auto OCd past what the CPU can handle and the PC will become unstable.
              AMD who are the ones to listen to state here up to 3200MT/s so unless you intend manually OCing the CPU 3200MT/s is your max.
              Something to keep in mind for the future, a CPU must be compatible with a MB whereas the RAM has to be compatible with both the CPU and the MB, this because a MB can be compatible with faster CPUs than the one in your list of parts and MB manufacturers often state RAM speeds that far exceed that which any compatible CPU in the board can handle.
              Operating System
              Windows 10 Pro 64-bit
              Computer type: Desktop
              [COLOR=rgb(184, 49, 47)]Installation Date: 2. 6. 2023 15:54:37
              Windows has not been correctly set up since day one, for as to why see my canned info below;
              Once Windows has been clean installed you must then install first the MBs chipset drivers then the storage/SATA drivers and third the graphics drivers, the drivers can either come from a disk provided by the motherboard manufacturer or downloaded from their site and saved to a flash drive etc, this is a must and Windows should not be allowed to check for updates before it has been done as more often than not Windows installs the wrong drivers or in the incorrect order and this can cause all sorts of problems.
              The reason why this procedure is so important, the chipset is what enables the MB to be able to communicate with all the hardware + are the first drivers that Windows looks for on boot
              The present installation is commonly referred to as a lazy install in my neck of the woods because that is exactly what it is, apart from the other issues one of the main reasons that performance sucks is because other than two HP printer drivers that were installed a week ago and one AMD drivers install three days ago you are running on generic Windows drivers
              Partition 1
              Partition ID: Disk #2, Partition #1
              [COLOR=rgb(184, 49, 47)]Drive Letter: C:
              File System: NTFS
              Volume Serial Number: AE53D4BB
              Used Space: 210 GB (88%)
              [COLOR=rgb(184, 49, 47)]Free Space: 27.6 GB (12%)
              You are about to run into problems with low storage space on the boot drive, see my canned info for this below;
              For Windows to be able to run efficiently and to be able to update you need to have between 20 and 25% of the partition or drive available on a HDD and an SSD between 10 and 15% as free storage space at all times, if you don`t you risk Windows becoming corrupt or not being able to update which puts you at risk of malware attack.
              [COLOR=rgb(184, 49, 47)]Please note that storage devices can physically fail if the amount of free storage space is allowed to drop below the required 10 or 20/25% minimum.
              Just a fyi, Windows should always be installed on either its own drive or on a separate partition on a larger drive, this reduces the amount of free space that is required to be kept available + it makes creating a regular back a whole lot easier.
              A 256GB SSD or separate partition on a larger capacity drive should be the minimum capacity allowed for.
              Equally as important is being prepared for the need to upgrade to another OS, Windows 10 is nearing its end of life and extended support will cease on October 14th, 2025, when the time comes you will only have to worry about upgrading or clean installing Windows to the C: partition as opposed to needing to reinstall all of your programs and data if they were kept on a separate partition on the same drive or a.n. other drive.
              Windows will also boot up quicker on its own partition as it does not need to install drivers for any third party programs.[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR]
              • MadoX
                • Oct 2019
                • 36
                Good to know, but I was thinking of upgrading my CPU either way.
                I didn’t know how to do that, didn’t think it was necessary either. Is there a way to do it now, to kind of save it ? Or do I have to do a clean reinstall of windows ?
                I used to have it like that, but back when I bought the PC the disk C: used to be my only SSD i’ve had. So I’ve started to download some small things into it as a way of making them run smoother, faster. Since then I’ve bought a new SSD that I use instead, but I kind of forgot to clean the old one so that it’s just the Windows again. I’ll definitely do that.
                Not the first time I’m hearing something like that, I’m looking for a new PSU as we speak, definitely going to replace the one I currently have and that’ll be the last aerocool **** that’s in my PC since i’ve bought it, except for the aerocool case lmaoo, the dude who built my pc must’ve loved aerocool.
                  The present GPU requires the system to be powered by a minimum of a 650W good quality brand PSU, allowing for the additional storage devices and screen 750W would be more appropriate, having looked in you part of the world the best unit that I could find is the one here less expensive than many 750W units, marginally more expensive than a few that only have a five year warranty and the Seasonic having a ten tear warranty means that it should still be around should you decide to build a new rig.
                  As is explained in my reply #7 the reason why this procedure is so important is the chipset is what enables the MB to be able to communicate with all the hardware + are the first drivers that Windows looks for on boot.
                  [COLOR=rgb(184, 49, 47)]A 256GB SSD or separate partition on a larger capacity drive should be the minimum capacity allowed for
                  Once Windows has been clean installed [COLOR=rgb(184, 49, 47)]you must then install first the MBs chipset drivers then the storage/SATA drivers and third the graphics drivers, the drivers can either come from a disk provided by the motherboard manufacturer or downloaded from their site and saved to a flash drive etc, this is a must and Windows should not be allowed to check for updates before it has been done as more often than not Windows installs the wrong drivers or in the incorrect order and this can cause all sorts of problems
                  Do the above preparation work as in saving the required drivers.
                  Back up what you need from the C: drive.
                  Reset Windows choosing the Remove everything option, see info here
                  Once done, disconnect the PC from the router, restart the PC and install the drivers in the order listed above.
                  Once the drivers have been correctly installed, shutdown the PC, reconnect the PC to the router, restart and test by using the computer as you normally would.
                  Post back with an update for us once the above has been done.[/COLOR][/COLOR]
                  • MadoX
                    • Oct 2019
                    • 36
                    #10
                    I did all of the above, downloaded drivers, reinstalled windows, also upgraded to windows 11. Now I’m getting pretty stable 144fps (V-sync capped), I still expected maybe too much out of my rig, but the bottleneck is really hurting my performance, even more than I anticipated. I’ll try to upgrade my cpu whenever I get the chance since my Utilization charts usually look like GPU is about 45-60% while cpu is at 90-95% lmao. Anyways thanks for the help guys, really appreciate it.
                      #11
                      Have you swapped in an appropriate Spec of PSU yet.
                      If you still require assistance, post a new Speccy url for us.
                        #12
                        @MadoX - any news?
                          #13
                          No follow up from the OP, thread marked and closed.
