Yellow light on motherboard for dram AND cpu.
  • PeterOz
    PCHF Technical Response Team
    • Mar 2021
    • 4181
    #91
    Originally posted by Mr. Rosy
    Okay so I’ve almost completed the installation and im at the screen where its trying to connect me to a wifi network, but it’s only showing ethernet as an option. I connected my MB antenna to the screws on the back, and nothing seems wrong but I’m not sure if I was supposed to do something to turn the antenna on.
    Sorry I was not here to answer I had to go to work.
    So you are running?
    Windows 10 or windows 11?
    Did you use
    Gigabyte Utilities Downloader to install the drivers?
    • Mr_Rosy
      • Jan 2024
      • 46
      #92
      I tried to use the Gigabyte utilities downloader when it popped up, but it said it failed to install the files after loading. I’m not sure what that means, but I think I only have the windows drivers right now. Is there a way I can access the utilities downloader again to try to get it to work?
      • PeterOz
        • Mar 2021
        • 4181
        #93
        Post #72 has the link and list of drivers
        • Mr_Rosy
          • Jan 2024
          • 46
          #94
          I finally got my computer working! Thank you so much for all of your help and support. The thread can be closed, and I will definitely consider donating.
          • PeterOz
            • Mar 2021
            • 4181
            #95
            All drivers from gigabyte installed?
              #96
              Glad you are sorted and thanks for letting us know (y)
              Just a btw, I hope that you will keep in mind that this would have been resolved a whole lot sooner if you had followed my guidance on the need to always have a keyboard attached from the outset
