Pc shuts down and fans go 100% speed with low hardware temperatures
  • Radeho
    • Dec 2023
    • 7
    Hello,
    I have been struggling with this problem for a few weeks now. It first started when I was playing a game and my pc shut down, screen went black and the fans went 100% speed. The first thought in me was a temperature issue, so I cleaned my whole pc of dust and put new thermal paste on the cpu and the gpu processor. This did the trick for 2 days and it then did the same crash again. I then changed the msi afterburner with a higher fan temperature graph, this worked a few days aswell, but then crashed again. I ordered 2 more fans to put in my case and a new pair of ram, because I thought this may solve the problem if it lied with the ram. Then strangely when I put the ram on xmp profile 1 in the bios, what I think should be duable, the boot of that configuration did the same crash with black screen and fans 100%. As a last solution I put my mhz of the ram to 2500 and it worked for a day until the same crash happened. I immeadiately felt my pc parts and they were not hot or even warm, so I don’t think it is a temperature issue anymore. Now I have no idea what to do and have come here for your help. Do I have to replace some parts, fix some settings or just buy a new pc?
    I also should add that whenever it crashes all the lights in the pc stays on and the red error light on the motherboard where it says cpu stays on and red. I think it should be a ram error then?
    My pc specs:
    I9-9900k
    RTX 2070 8g armor
    Z390 ud (I have heard that this is not a decent motherboard)
    Bios: F10k
    Old ram: G.skill tridentz rgb 2x8gb 3000 mhz
    New ram bought for replacement: G.skill tridentz rgb 2x8gb 3200 mhz
    Cooler master 212 evo
    4 fans in case, 2 from nzxt and 2 from be quiet
    A 650 w 80+ bronze psu (Don’t know the brand anymore)
    Extra info: I have this pc for about 5 years I think and added the i9 in 2021.
    I use this pc to game a lot and study on.
    Began this year with editing some vids
    Radeho
    We understand that computer issues can be stressful but please do not start more than one thread looking for help with the same issue, this not only wastes helpers time but can also lead to confusion as to who`s and what guidance you are following which in turn can lead to mishaps and potentially irreparable damage to your computer.
    Continue at your first thread here
    This duplicate thread has been closed as per the above.
