AORUS Z390 PRO WIFI MOTHERBOARD wont post or even power on
  • Joshua_Tidwell
    • Dec 2023
    • 1
    I need help if possible, please someone? the motherboard will only power on for 2 secs. then nothing will work. no fans, no lights, no power to anything. Tested power supply, all ok. memory swap ok. not sure what else to do. Please any help
    • 15205
    Sorry but you have post on a tech forum asking for help but have provided zero information about your computer or it`s hardware, this makes it impossible for anyone to even hazard a guess as to what is going on.
    Has this computer ever worked or is it a new build.
    If not a new build, what happened exactly, was it working and turned off, any settings changed, dead the next day after being fine the day before etc.
    Can you post the brand and model name or number for the CPU, the RAM ( including the amount, number of sticks and speed ) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better help you.
      • 15205
      Being that the OP revisited the forum but chose not to reply this thread will be closed.
