Monitor disconnects, fans blow at full speed
  • RedPuffin
    • Dec 2023
    • 3
    Hey guys,
    I have been having an ongoing issue over the last few weeks. Randomly while gaming, my monitor screen disconnects and the fans ramp up to max. Sometimes i hear a loop of sound, but i can’t do anything other than restart. I recently bought a new monitor, this disconnects as well. Old one was connected through HDMI, this one through DP.
    I have tried to stress test both CPU and GPU, and have had no issues.
    It started off happening roughly 3 hours into a gaming session. At the time i was mostly playing overwatch. I read that other people were having a similar issues, so i assumed it was the game crashing… However, i noticed it happened on Elder Scrolls online as well. Lately it’s been happening a lot sooner, within 30min usually and sometimes as quickly as 2min into launching the game.
    I loaded up Cyberpunk, put everything on Ultra, inc Ray-tracing… it ran at 20-30fps, but no issues… Same with Red Dead Redemption 2.
    I have a RTX 3080
    11700KF
    MSI Z590 Pro Wifi (CEC)
    system is liquid cooled.
    Windows 11
    usually when gaming, the GPU stays steady at around 70 degrees even when maxed… During stress test, it peaked at 76.
    During CPU stress test, CPU reached a high of 79 degrees.
    I updated BIOS, Windows and all drives… still happening.
    Any Ideas?
    Give us your complete psu spec’s..
    Download and post .
    To post.
    • RedPuffin
      • Dec 2023
      • 3
      Originally posted by veeg
      Download and post .
      To post.
      • Rustys
        • 7862
        • RedPuffin
          • Dec 2023
          • 3
          PSU is MSI A750GF
            for the RTX3080, the min PSU is 750w, so you are already at the limit.
            sites like this one; https://support.lumion.com/hc/en-us/...y-do-you-need- recommend 900w minimum.
            you also have two antivirus programs enabled.
            use the Nortons Removal Tool to remove it and see if that helps. you can always reload it later.
