Max fan speed on video card even if PC doesn't loaded
  • Vlad_Ivanchuk
    • Feb 2023
    • 15
    Hello everyone. I’ve had this problem for a really long time, but I’ve only decided to solve it now. So, my problem is that even when idle, my video card fans are running at maximum speed. However, I recently managed to resolve part of the issue. I noticed that my video card fans didn’t turn on at maximum speed when the computer is starting up or during the BIOS stage. Interestingly, this particular model of video card has a feature that allows the fans to be turned off when the computer is idle and not under heavy load. Unfortunately, this function is broken as it keeps enabling itself even after I disable it through a proprietary program from AMD. Is there any solution to my problem?
    My video-card is AMD radeon RX580(8gb)(company HIS)
    Video where I am demonstrating my problem https://drive.google.com/file/d/16Oe...ew?usp=sharing
    My version of AMD software:[ATTACH type=“full”]12102[/ATTACH]
    Give us your complete psu spec’s .
    • Vlad_Ivanchuk
      • Feb 2023
      • 15
      Chieftec GPS-600A8, but i don’t think problem with psu, because if i put into the computer another video-card everything is ok
        Looks to be a sub par psu..
        @phillpower2
          The PSU is complete junk, ten years old and no efficiency rating of any kind means that it 100% should not be used anywhere any add on GPU, the two year warranty period it had tells you just how poor the quality was.
          Regarding the GPUs fan behaviour, not enough information to go on atm.
            No reply from the OP so closing thread as abandoned.
