need help with compatible cpu with my motherboard
  • Cody_Kristof
    • Nov 2022
    • 3
    [HEADING=2]i have a Predator PO3-630G with a intel i5-11400F Hexa-core (6 Core™) [/HEADING]
    and want to upgrade to a i7 but dont know what version is compatible can any one help
    any LGA1200 socket processor should work.
    make sure the BIOS is the latest to be compatible with all the latest processors.
    what speed is the current i5 - 2.9GHz?
    if so, make sure the new i7 it at least 8 core and 3.6GHz otherwise you probably won’t see too much improvement.
    • Cody_Kristof
      • Nov 2022
      • 3
      [ATTACH type=“full”]10821[/ATTACH]
      • Cody_Kristof
        • Nov 2022
        • 3
        would this work
        [ATTACH type=“full”]10822[/ATTACH]
          can’t see why not, although it is a generation backwards from what you currently have.
          and it’s only 2.9GHz compared to your current 2.6, so not a massive jump at all.
          when it says “up to 4.8” that’s with over-clocking, something your current processor could do.
          but in my opinion, not a rabbit hole you want to go down.
            @Cody Kristof - still need help?
              abandoned
