GPU usage fluctuations followed by fps drops and also Texture popping with Poor LOD draw distance.
  • Pyro
    • Jan 2019
    • 1189
    #16
    You could try it.
    Worst case scenario you go back and do a complete re-install from scratch.
    It should be noted, I’m not positive if this will keep your current drivers or delete them, it’s possible it will keep all of your drivers and leave you in the same boat.
    That being said, let’s get a couple more opinions in here before we take such a drastic step.
    @Bruce @PeterOz @Bastet
      • 10697
      #17
      yeah - not my cup of tea really.
      Ryzen CPU’s, gaming, FPS drops, high-end GPU’s and all that.
      then trying to eek out performance gains with a GPU vs CPU balance act.
      I’ve always been a believer of simply getting better components, in this case, matching a new, better CPU to a latest gen GPU so your system specs exceed the requirements of the games.
      I’ll let others wade in that have more skin in the game than I.
      • Arvind
        • Aug 2022
        • 19
        #18
        Originally posted by Pyro
        You could try it.
        i did do a clean install once again using ddu and offline.. also i tried older drivers as well.. did not work..
        • Arvind
          • Aug 2022
          • 19
          #19
          i dont mind getting a better and high end CPU if its gonna fix my issue.. but i need to make sure it is gonna work first..
          • Arvind
            • Aug 2022
            • 19
            #20
            Also the Gpu usage drops follwed by Fps drops occurs at specific moments or when looking at a specific way.. for example if i look at the sky it jumps to full usage and stays constant.. or if im in a desert like place.. but when there are buildings etc.. then it starts getting the usage issue.. do you think that’s CPU or GPU related? Think its CPU cause its the Cpu’s job to provide data of details.. in that case, im getting poor LOD. Or it can be my Gpu not processing data fast enough..
            but from what i saw in benchmark all seem smooth..only tested unengine.. any other benchmark that i can try plz?
            • PeterOz
              PCHF Technical Response Team
              • Mar 2021
              • 4181
              #21
              bench marks don’t reall relate to the games in my opinion
              Change your power setting to Balanced.
              It is not just the gpu drivers you have to worry about on a new install
              it is also Chipset drivers
              When you are finished with the install, then install your drivers. Install the chipset first then the rest of them. Reboot each time when prompted.
              From here a list on how to install Proper Installation Order for Windows Drivers
              • Bastet
                • Aug 2016
                • 1515
                #22
                Did you run DDU under safe mode?
                Do you have dual graphics - Intel/AMD + nVidia?
                Are those games running with the nVidia graphics?
                • Arvind
                  • Aug 2022
                  • 19
                  #23
                  i did install and update to latest chipset as well as drivers…
                  • Arvind
                    • Aug 2022
                    • 19
                    #24
                    Yes used DDU in safe mode,
                    No i dont have integrated graphics… only my Rtx 3070 as GPU
                    Nvidia graphics? wdym?
                    • Arvind
                      • Aug 2022
                      • 19
                      #25
                      i added a new game to the test today.. Elden ring.. And again same issue.. Random Stutters with Gpu usage drop and FPS drop.. LOD issues as well with leaves and trees rendering properly as i get close.. same for shadows..I am getting another processor(5 2600 as i am not finding any friend with a better one)and Gpu(rx590) tommorow to test..
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #26
                        Do you have a separate modem and router
                        If yes can you hardwire straight to the modem
                        • PeterOz
                          • Mar 2021
                          • 4181
                          #27
                          [HEADING=1]Recommended Specs[/HEADING]
                          Using the recommended specifications for Marvel’s Spider-Man Remastered, you’ll be able to achieve 60FPS at 1080p resolution, using Medium graphics settings according to Insomniac Games.
                          OS Windows 10 64-bit
                          Processor Intel Core i5-4670 or AMD Ryzen 5 1600
                          Memory 16 GB RAM
                          Graphics NVIDIA GeForce GTX 1060 6GB or AMD Radeon RX 580
                          DirectX Version 12
                          Network Broadband Internet connection
                          Storage 75GB SSD
                          Processor Intel Core i5-11400 or AMD Ryzen 5 3600
                          Memory 16 GB RAM
                          Graphics NVIDIA GeForce RTX 3070 or AMD Radeon RX 6800 RT
                          DirectX Version 12
                          Storage 75GB Available Space
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #28
                            Elden Ring
                            [li]MINIMUM:[/li]
                            • [li]Requires a 64-bit processor and operating system[/li][li]OS: Windows 10[/li][li]Processor: INTEL CORE I5-8400 or AMD RYZEN 3 3300X[/li][li]Memory: 12 GB RAM[/li][li]Graphics: NVIDIA GEFORCE GTX 1060 3 GB or AMD RADEON RX 580 4 GB[/li][li]DirectX: Version 12[/li][li]Storage: 60 GB available space[/li][li]Sound Card: Windows Compatible Audio Device[/li][li]Additional Notes:[/li][/ul]
                            [li]RECOMMENDED:[/li]
                            • [li]Requires a 64-bit processor and operating system[/li][li]OS: Windows 10/11[/li][li]Processor: INTEL CORE I7-8700K or AMD RYZEN 5 3600X[/li][li]Memory: 16 GB RAM[/li][li]Graphics: NVIDIA GEFORCE GTX 1070 8 GB or AMD RADEON RX VEGA 56 8 GB[/li][li]DirectX: Version 12[/li][li]Storage: 60 GB available space[/li][li]Sound Card: Windows Compatible Audio Device[/li][li]Additional Notes:[/li][/ul]
                            • Bastet
                              • Aug 2016
                              • 1515
                              #29
                              Via the nVidia control panel you can set a specific program to run with a specific graphics card. I have Intel & nVidia & some games refuse to run with the Intel graphics but run when nVidia is set as the default card for that game.
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #30
                                I posted the specs so if you buy any equipment make sure you meet the recommended specs
                                minimum specs will be basic
