Building a PC, need help!
  • Koova
    • Aug 2022
    • 1
    Hey i have a Macbook Air and he can’t run After effect that well and I need to create some explainer video (animating illustration in AE)
    and I am thinking of this build since I am on tight budget
    INTEL CORE I3 9100F
    Nvidia GT 710
    16GB RAM
    And with an SSD
    Can I have an ok performance with this?
    And I can play the playback without dropping frames?
    I will be using this only on AE no 3D only illustration
    that’s a low-end processor and a low-end, and old, graphics card.
    it’ll be OK but your level of OK may not be the same as mine.
    I haven’t used AE, but being Adobe, you’d be expecting it to be a resource hog, and the three components it would like the most (CPU, RAM and graphics), two of those you have hobbled.
    personally, I’d be adjusting my budget.
      @Koova - still need help?
      • Rustys
        • 7862
        abandoned closed thread
