Help with 5800x Ryzen Master Settings?
  • muttsang
    • Apr 2022
    • 2
    Hello all,
    I just started my career in game programming and we have to use pretty heavy stuff like the Unreal Engine where we have to compile the source quite a lot.
    This took a very long time (sometimes upto 5/6 hours) with my Ryzen 7 2700x CPU and so I’ve just upgraded my PC with a Ryzen 7 5800x CPU.
    I’m using a stock Wraith Prism cooler for now as I’ll need to save up some money for a better cooler and I’ve noticed immediately the temps are higher than my old CPU. For instance during idle, the temps range from 35 to 40 degree Celsius and when I open the file explorer it goes to around 50 degree Celsius.
    I don’t think the temp should jump to 50-56 by just opening the explorer.
    I also am seeing a feature called the “Curve Optimizer” in Ryzen Master which I have no idea what it does.
    Could anyone recommend me good Ryzen Master settings for my CPU please? I’d prefer using the Precision Boost Overdrive as well.
    My specs are:
    CPU: AMD Ryzen 7 5800x
    Motherboard: Gigabyte X470 Aorus Ultra Gaming ATX AM4 Motherboard
    RAM: 32 GB
    Power Supply: Corsair TXM Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply
    Thank you
    So you are saying you need help with your cpu pertaining to your job?
    • muttsang
      • Apr 2022
      • 2
      Originally posted by veeg
      Hi,
      Yes that seems like a better way to put it ???
        Ok ..i am sorry as per rule.. 15. PCHF can not and will not offer advice for business use or financial gain. PCHF only offers assistance for personal use.
