The impossible problem of no display and no usb power. Try me, I tested everything.... help!!!
  • Alex_Labgon
    • Mar 2022
    • 24
    #16
    Sooo, i just take a quick look of the snapshot that Speccy took.
    I found quite a lot of info that I’m not sure if it would be quite right to be publish on ethernet.
    Either way, if something is really important tell me and all give you the info of the snapshot
    Bad pc
    PSU: 750W 80 plus - corsair
    Motherboard: ASUS ROG b550-F
    SSD: M.2 NVMe 1.4 Samsung 980 250Go
    HDD: Seagate 1To
    RAM: Corsair Vengeance LPX 16Go DDR4 3600
    Case: NZXT H710i White
    Thermal paste: Graphite Pad by Innovation Cooling
    CPU: AMD Ryzen 7 3800X 8cores
    CPU cooler: AMD’s CPU included fan → LED Wraith Prism
    GPU: ZOTAC RTX 3060 OC 12Go GDDR6
    (Same as the first post)
    My good pc
    PSU: EVGA supernova 500W 80 plus gold
    SSD: M.2 NVMe 1.4 Samsung 980 500Go
    HDD: Seagate 500Gb
    Case: Corsair SPEC-05
    CPU: AMD Ryzen 5 3600X 8cores
    GPU: ASUS GeForce GTX 1660 Super OC 6Go EVO
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      #17
      There is nothing in speccy that can give away who or where you are.
      It might show your first name - might not
        #18
        people baulk at the IP addresses contained in Speccy.
        these are of no use to us as they are LAN IP’s (inward facing), rather than WAN IP’s (outward facing).
        in Speccy, I would see your PC is on 192.168.1.20 and your default gateway is 192.168.1.1 (as examples).
        these do nothing if I was a hacker trying ‘to get in’.
        Speccy doesn’t even show your ISP’s WAN address which would be the only thing I can ping.
        • PeterOz
          • Mar 2021
          • 4181
          #19
          Try 1 stick of ram only in slot B1
          If no bios try another stick in B1
          Pic attached
          • Alex_Labgon
            • Mar 2022
            • 24
            #20
            Hey Peter, thanks for the tips.
            Unfortunatly i tried playing with the RAM multiple time and even only on RAM in “B1”
            It hasn’t work…
            • PeterOz
              • Mar 2021
              • 4181
              #21
              Last option I can think to do is flash bios
              • Alex_Labgon
                • Mar 2022
                • 24
                #22
                i checked asus support website yesterday and followed the step to flash my bios
                and it didn’t work
                Im burn this PC lol
                I cant think of the problem could be now
                • Alex_Labgon
                  • Mar 2022
                  • 24
                  #23
                  Im only running CPU, GPU, PSU, MB, RAM, and the two pin powerswitch of the case
                  bare minimum
                  I get no warning beeps
                  but I’m thinking of testing the cpu cause the PSU, MB are new, and I swap gpu with my PC and his gpu work in my pc
                  reseating ram and swaping it make nothing but they work all in my pc
                  I can only imagine the cpu to be the problem now idk
                  I might have to restest it
                  • PeterOz
                    • Mar 2021
                    • 4181
                    #24
                    Flash of the bios did not work or
                    Bios update worked and no difference to booting
                    • Alex_Labgon
                      • Mar 2022
                      • 24
                      #25
                      I flash the bios using a usb key and the flash bios button on the mb
                      the flash bios led had light up
                      but the problem persist
                      also weird that the MB he had first (before I replace it with the same model but new to troubleshoot) is in my PC without any change and work good
                      • PeterOz
                        • Mar 2021
                        • 4181
                        #26
                        swap psu
                        I know yours is new BUT
                        • Alex_Labgon
                          • Mar 2022
                          • 24
                          #27
                          Well when the problem occur, he had a 650W psu
                          After all the testing I though it would be the psu
                          I bought a 750W psu and install it myself and still nothing
                          • PeterOz
                            • Mar 2021
                            • 4181
                            #28
                            24 pin power or 8+4 pin power
                            • Alex_Labgon
                              • Mar 2022
                              • 24
                              #29
                              MB power?
                              • PeterOz
                                • Mar 2021
                                • 4181
                                #30
                                Yes ATX Power
