Is this fan speed normal for idle mode?
  • mhmd
    • Dec 2021
    • 1
    My PC CPU fan had abnormal sound (probably works fast) and I decided use SpeedFan to monitor Fan’s speed in RPM and CPU’s temperature in centigrade.
    Look this picture:
    [ATTACH type=“full”]8737[/ATTACH]
    This information is for idle time, when I don’t have any heavy process…
    I’ve also checked the BIOS setting for fan configuration, but fan speed has set on the Standard mode !
    As it seems, CPU is cold and 26’c is not much, but is 2842 RPM normal for this temp?
    CPU Core i3 8100
    Motherboard ASUS H310M-C R 2.0
    CPU Cooler is default Intel Cooler
    Speedfan only shows one fan,is this correct? If not you may have some fans that have failed.. You need more air flow..
      @mhmd, do you still need help?
        Closing thread
