CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2: CPU Thermal Compound - Our Cooler Master MASTERGEL High Performance Thermal Compound can improve cooling performance as well as prolong the life of your CPU. [+10]
CAS: CyberPowerPC NR640 High Air Flow Mid-Tower Gaming Case with Tempered Glass + 4x 120mm ARGB Fans [+2] (Black Color)
CPU: Intel® Core™ Processor i5-10600KF 6/12 4.10GHz [Turbo 4.8GHz] 12MB Cache LGA1200 [w/o Integrated Graphic] (Comet Lake-S) [+0]
FAN: CyberPowerPC MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate
HDD: 1TB WD Blue SN550 Series PCIe NVMe M.2 SSD - Seq R/W: Up to 2400/1950 MB/s, Rnd R/W up to 410/405k [-13] (Single Drive)
MEMORY: 16GB (8GBx2) DDR4/3600MHz Memory [-50] (Team T-Force Delta RGB)
MOTHERBOARD: MSI Z590 PRO WiFi ATX, ARGB, WiFi 6, 2.5GbE LAN, 2 PCIe x16, 2 PCIe x1, 6 SATA3, 3x M.2 SATA/PCIe [-31]
NETWORK: Onboard Gigabit LAN Network
OS: Windows 10 Home (64-bit Edition). Free Upgrade to Windows 11 *(see below) [+0]
POWERSUPPLY: 750 Watts - CoolerMaster MWE GOLD 750 - V2 80 PLUS GOLD Ultra Quiet Full Modular Power Supply [+22]
PRO_WIRING: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
VIDEO: GeForce RTX™ 3060 12GB GDDR6 Video Card (Ampere) [VR Ready] [+458] (Single Card)
$1,606 after tax. custom build
OR
Operating System ::Windows 11 Home
Case ::iBUYPOWER Slate HAKO MR Tempered Glass ARGB
Processor ::Intel® Core™ i7-11700KF Processor (8X 3.60GHz/16MB L3 Cache)
Processor Cooling ::iBUYPOWER 240mm Addressable RGB Liquid Cooling System
Memory ::16GB [8GB x 2] DDR4-3600MHz RGB
Video Card ::GeForce RTX 3060 Ti - 8GB GDDR6 (VR-Ready)
Storage ::1TB Samsung 980 M.2 PCIe NVMe SSD
Motherboard ::ASRock Z590-C/AC
Power Supply ::600 Watt - 80 PLUS Gold Certified
Internal Wireless Network ::On-Board Wireless Network
$1,817 after tax. pre-built.
what do you think? which is better? which will last longer? it’ll be used for primarily gaming. minor amounts of adobe stuff/editing
OR
