got hardware problem not sure is it graphics card or PSU problem
  • guymero
    • May 2021
    • 1
    this is kinda old system everything have been worked before, problems start month ago starting to get multiple different blue screens so i bought ne motherboard and rams that worked on those.
    but now got new problem the PC just shuts down log information just says PC turned off suddenly.. was monitoring core temps and found out that gpu was over heating so i open it up it (seemed that some angry overworker had to piled it up) had to fix here and there that cooling, but after switching thermal paste and fixing other issues on memory cooling i got it working was testing with Heaven Benchmark and max heat was (79C)/ (174,20) fans was half power.
    well it did not fix the problem every time when i played a game i got random system shut downs i tried out switching mem and cpu same thing happening but after switching out 5700xt to my old 1060 6gb it stopped so i was thinking first is my gpu dead or what ..but then i was thinking it takes less power so i switched back to 5700xt and i took off VR system and it started working without shut downs well i don’t think that it threw out that gpu is broken but is it a more likely that PSU is failing i have it about 10 years now used on 3 different systems
    • 15206
    You are most likely correct, PSUs get hot inside as they start to age and you have done well for your PSU to have lasted so long, what is the brand and model name or number of the PSU.
      • 15206
      Thread closed due to lack of any feedback from the OP.
