How do I control the fan speed or cooler itself from an AIO cooler?
  • papercuz
    • Apr 2021
    • 2
    I have installed my lian li Galahad 360 onto my Rog strix B550 Gaming-a. Now there were two connections: Connect to AIO_Pump which I did on the motherboard and the other is either connect them to Sata of the power supply or Motherboard. This is what the connection looks like: [MEDIA=imgur]a/5m1DFTk[/MEDIA] For the basics three RGB fans that is attached on the AIO, It says to connect it to the 4 pins PWN. But I’m wondering if i can connect it to 1 for CPU_FAN and 1 for CPU_OPT? And the last fan for 4 pins PWN.
    Because i noticed that when i play a certain game, my restarted my pc.
    I also wanted to mentioned when I first installed the AIO cooler. The pc mentioned no cpu cooler was installed, so i went to bios mode and overwrote it.
    If anyone can help. That would be much appreciated because I have no clue on how to change my AIO fan speed or the cooler itself.
    @PeterOz
    • PeterOz
      PCHF Technical Response Team
      • Mar 2021
      • 4181
      Did you follow the instructions Paperdoc gave you when you asked the question on Tom’s hardware
      Link to Tom’s Hardware
      • Rustys
        • 7862
        thread closed user following instruction on other forums
