Pc won’t turn on,front panel connectors not working right on B450 aorus pro
  • Epic_berserk
    • Feb 2021
    • 2
    I have built my first pc and made sure everything is plugged in right. However I need help. My pc won’t turn on. When I first tried to turn my pc on the leds for the case power button didn’t show and the pc didn’t turn on. I put the connectors in the right space according the manual. After messing about I found out the leds work in the power switch space only and not the ones shown. They don’t work anywhere else. I have made sure I have put + with +. The power switch doesn’t seem to work in any of the spaces and I have also tried shorting to see if it works however I got no response. Could it be my motherboard is faulty? Or the case switch is faulty?When I first turn my pc on the motherboard led lights flicker once and that’s it also my ram led lights work. So I am stuck on what to do. Can anyone help?
  • jmarket
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Hello,
    Could we have some more information about your system please? Particularly:
    Motherboard Make and Model
    Case make and model
    • Epic_berserk
      • Feb 2021
      • 2
      Originally posted by jmarket
      Hello,
      Case make and model
      My motherboard is the gigabyte aorus b450 pro
      And my case is the lian li pc 011 dynamic
      I also have Corsair cxf 550w, cooler master mf120 fans, and ryzen 2700x
        can we see a few shots of your build, in particular, cables, connections, memory, CPU, hell - everything.
        sounds like something has been missed.
        I would take it all apart and build it on a piece of cardboard on the floor.
        hopefully that way you can troubleshoot components easier.
        • Rustys
          • 7862
          Do you need any further assistance
