Help with my CPU cooler RGB?
  • adamschafer
    • Dec 2020
    • 1
    First of all here’s my new specs on my PC
    Corsair 4000D
    RTX 3080 VENTUS 3X OC
    i9 10850K
    Corsair iCUE H150i ELITE CAPELLIX cooler
    Corsair 64GB RAM
    SN750 1TB SSD
    ROG STRIX z490-E motherboard
    Thermaltake Pure plus triple fans
    Everything is working besides the RGB on my CPU cooler, it was working before now its not. There’s a 1 pin cable coming out from it, maybe its plugged in the wrong spot but I can’t figure out where on the motherboard to plug it in. I think the 1 pin cable is for the RGBs? I have no idea. Any help would be appreciated!
  • Rustys
    • 7862
    Have you referred to your manual? Page 1-16
    You might try switching from A to B or re seating the connection maybe it came loose one end or another?
      Thread closed due to lack of any feedback from the OP.
