Driver not installed successfull
please i need help
Do you not think that it just might be helpful if you actually explained what happened
You need to check the drive with the proper WD tool which you can download from hereComment
You still havn`t told us what happened when you tried to install the driver.
If I need to keep on asking for feedback from you then you will have to find someone else to run around after you.Comment
