problem with external hard drive
  • beponeko
    • Feb 2020
    • 5
    It doesn’t show up anywhere. When I first plugged it in it worked fine but I couldn’t install some games onto it, so I tried reformatting it and now it’s just gone. So I guess I have two problems, first that I couldn’t install some games on it and now that it’s gone Help please thanks
    It’s an Intenso 2,5’’ 500GB if it matters
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    Can you try the drive with another pc and see if it shows?
    Can you also take a screenshot of your disk management screen with the drive connected to the pc it doesnt show on?
    • beponeko
      • Feb 2020
      • 5
      Tried plugging it into my laptop and didn’t show up there either.
      Here is the disk management
      [ATTACH type=“full”]5801[/ATTACH]
      • system
        PCHF Owner
        • 7695
        • CachyOS
        Looks like your drive or the usb connection to it may have died. Can you take the drive out of its enclosure and connect it directly to another pc?
        • beponeko
          • Feb 2020
          • 5
          I don’t think it can be taken out without somewhat breaking it and I don’t have any other pc to connect it to
            Any updates?
