PC won't power down but also won't display anything on monitor
  • B_Kellz
    • Feb 2020
    • 11
    #16
    Is there any PSU brands you would recommend going with?
      #17
      You are welcome and good luck (y)
      [COLOR=rgb(44, 130, 201)]Edit to add: Corsair, EVGA or Seasonic, will see what I can find and come back to edit this post.
      [COLOR=rgb(226, 80, 65)]Additional edit, I would normally suggest a Gold efficiency rated PSU for a high end GPU but seeing as yours is used I suggest a Bronze efficiency rated PSU but being honest would strongly suggests that you get the GPU tested before making any purchase. EVGA 500W ATX Power Supply[/COLOR][/COLOR]
        #18
        Any update for us?
        • B_Kellz
          • Feb 2020
          • 11
          #19
          Sorry got messed around with my delivery only got it today!
          All set up now with a Corsair 750w gold standard PSU, everything seems to be working fine. Been running for the last 2 hours, things even seem to be running slightly faster and with a lot less noise coming from the PSU too.
          Again thank you for all your help!
          • jmarket
            PCHF Owner
            • 7695
            • CachyOS
            • Intel Arc A770 (16 GB)
            #20
            Glad you got it working
            Do you consider this resolved or would you like us to keep this open for a few days?
              #21
              Glad to hear that the bad PSU has not damaged anything else and thanks for letting us know (y)
              Just a couple of the benefits of having a good quality brand of PSU that has the appropriate output, you chose well
              You are welcome
              • B_Kellz
                • Feb 2020
                • 11
                #22
                [/QUOTE]
                I defiantly consider this resolved, once again thank you for the help. Will defiantly use again if I have any more problems!
                  #23
                  You are welcome and thank you for concluding your thread B_Kellz (y)
