Lighting Problems with Custom Built PC
  • arch11m
    • May 2019
    • 2
    Hi!
    About a year ago I decided to build my first PC. Here are my specs:
    MSI X470 Gaming Plus
    AMD Ryzen 7 2700
    AMD Wraith Spire
    Corsair Vengeance Pro RGB16GB
    ASUS 1070TI Strix Advanced GPU
    EVGA SuperNOVA G3 550W
    Western Digital 1TB
    Samsung 970 EVO 500GB SSD
    CoolerMaster MasterCase H500P
    I’ve always had lightning problems, and today I thought I’d finally try and resolve it. I currently have to use multiple different software to control my lights (Mystic light, ASUS Aura, iCue). I’ve been told to use my motherboard’s lighting software to control everything, and this is where my problem starts.
    On Mystic Light 3, only my motherboard and RAM are recognised. Nothing else. I can easily control my RAM individually, but if I try and adjust my motherboard colour, it changes my fan lights and my CPU Cooler too, however my CPU cooler becomes the opposite colour. For example, if I turned my motherboard purple, the fans would turn purple, but the CPU cooler would turn green. I’ve never been able to change the CPU cooler from either green or red, depending on whatever colour I choose for the motherboard.
    I would really like to be able to adjust them individually, as at the moment, my CPU cooler nor my fans are recognised on any software.
    If anyone has some advice or more knowledge than me it would be really helpful.
    Thanks,
    Archie
    Hopefully some of our members will chime in soon.
    @phillpower2 @Evan Omo @Bruce
      So not my area.
      It’s one of the avenues in PC mods that I never went down.
      Never saw the need to make my rig flashy and shiney.
        Like Bruce, not my area i`m afraid.
        Alternative to MSI Mystic Light with unlocked colour control and customizable effects
        • Evan_Omo
          • 1257
          Hi Archie. Have you double checked your LED connector cables that are plugged into the motherboard to ensure that they are not plugged in backwards or in the wrong port? Having LED cables not connecting properly can cause the issues you are describing but beyond that that is honestly all I can suggest.
          • arch11m
            • May 2019
            • 2
            Hi!
            I’ll try that today. I was thinking that myself but didn’t want to try until I heard from you guys. Thank you, i’ll let you know.
              Any update arch11m?
