No post, cpu fan starts and stops, case and video card fan starts
  • redcrit
    • Oct 2018
    • 9
    #16
    It works !!!
    It was the dumbest thing ever, I just had to drop the vga conection on my mobo because it does not work, and conecting it on the graphic card it works now !!!
    Now how can I make the hdmi and vga entry of my mobo to work please
    • system
      PCHF Owner
      • 7636
      #17
      Are you trying to use both your motherboard and graphic card ports together???
      Depending on your motherboard you may not be able to use both the onboard and addin card graphics at the same time. If you wish to use onboard graphics from the motherboard then remove the addin graphics card and then install the graphics drivers from the motherboard manufacturers site.
      • redcrit
        • Oct 2018
        • 9
        #18
        Yes I am.
        "If you wish to use onboard graphics from the motherboard then remove the addin graphics card and then install the graphics drivers from the motherboard manufacturers site. "
        Yes I wish, I did install the graphics driver from the motherboard, but it has no effect…
        Here in graphic it says N/A, it means there are no graphics in this motherboard ASRock > AB350M
        Why in the driver section you can download “AMD all in 1 with VGA driver” then ?
        Why does the motherboard have VGA, HDMI, DVI port then ?
        • system
          PCHF Owner
          • 7636
          #19
          Originally posted by redcrit
          Yes I am.
          The motherboard model you quote above does not have any graphics ability, therefore you cannot use any onboard/motherboard graphics with it. There are no graphics ports on it.
          This motherboard you quoted in the previous post above is very different to the motherboard you quote in post 1 of your thread.
          Perhaps you should advise us of the ACTUAL motherboard you are using before we attempt to clear the confusion here?
          • redcrit
            • Oct 2018
            • 9
            #20
            Sorry indeed I made a mistake in my last post it’s not AB350B it’s it AB350m it’s ab350m PRO4. Why does it have Vga, dvi and hdmi port if they can’t work ?
            • system
              PCHF Owner
              • 7636
              #21
              The rear panel connectors of the ABM350 pro4 board indeed have connectors for video output.
              [ATTACH]4203[/ATTACH]
              This motherboard supports onboard graphics, but when a dedicated graphics card is installed as you have done the onboard (rear panel motherboard connectors are disabled by the bios. There should be no reason why you should want to use both the graphics card and motherboard connectors at the same time anyway. The graphics card will generally give better graphics performance and reduce the use of computer resources.
                • 8977
                #22
                Any updates for us?
                • Rustys
                  • 7862
                  #23
                  @redcrit the thread will be closed in 24 to 48 hours.
