My pc is making a very loud noise and im not sure what's the cause
This topic is closed.
  • tomer15s
    • Jul 2018
    • 23
    Heres a link to an audio recording:
    Have you checked your fans? Also listen to see if your hard drive is making that noise. You will have to open the side panel..
    • Rustys
      • 7862
      Is this a desktop or Laptop?
      Sounds like a fan needs to be replaced.
      • tomer15s
        • Jul 2018
        • 23
        Originally posted by vger
        Hello, im currently running a chkdsk command and after its done ill open the side panel and determine if its the fan or the hard drive, will come back after that.
        • tomer15s
          • Jul 2018
          • 23
          its a desktop, ill open pc after the chkdsk and see whats up in there, i guess ill post a video for you guys to analyse
          • tomer15s
            • Jul 2018
            • 23
            ok im back, the chkdsk didnt give any errors however i booted into bios and set the settings there to default and that seemed to fix the problem
            • tomer15s
              • Jul 2018
              • 23
              It actually created another problem where the monitor loses signal after a while and the pc then restarts itself
              edit: ok i opened up the pc and one of the gpu fans was out of the gpu so i put it back in and things are ok now
              • Rustys
                • 7862
                Keep an eye on that in case it pops out again. If that card is not that old may wan to get it replaced or think about it in the future.
                  Any updates for us?
