Parts compatibility
This topic is closed.
  • karciukas123456
    • Sep 2018
    • 7
    Parts compatibility
    Hi, so I was thinking about upgrading my PC setup with a GTX 1080-ti, but I’am not a PC guy so I don’t really know if it will be compatible with other parts. So I would like to know if my current setup would work with 1080-ti or would I have to upgrade other parts as well.
    Here is what I’am currently working with:
    Processor:
    Intel Core i5-4690K, Socket-LGA1150
    Quad Core, 3.5GHz, 6MB, 88W, 22nm, HD4600, incl. cooler
    Wirless Adapter:
    ASUS PCE-AC56 AC1300 Trådløs Adapter
    Dual Band AC PCI-E Adapter 400+900Mbps
    Storage:
    HyperX Fury SSD 240GB 2,5"
    SATA3.0, 7mm, SF-2281, 500/500MB/s read/write
    Seagate Barracuda® 2TB
    SATA 6Gb/s (SATA 3.0), 64MB Cache, 7200RPM, 3.5"
    Power Supply:
    Corsair CX 750M, 750W PSU
    ATX 12V V2.3, 80 Plus Bronze, Modular. 4x 6+2pin PCIe, 8x SATA, 6x Molex
    Memory:
    HyperX Fury DDR3 1600MHz 8GB Black
    2x4GB 1600MHz DDR3 CL10 DIMM (Kit of 2) HyperX Fury Black Series PnP
    Case:
    Corsair Carbide 200R Midi Tower Sort
    1x 120mm Front, 1x 120mm Bak, mATX, ATX, 2x USB 3.0
    Motherboard:
    ASUS B85M-GAMER, Socket-1150
    m-ATX, B85, DDR3, 1xPCIe-x16, Intel GbLAN, VGA,HDMI, SupremeFX
    Video Card:
    Gainward GeForce GTX 970 4GB
    PCI-Express 3.0, DL-DVI-I, mini-HDMI 2.0, 2x mini-DP, UEFI
    Monitor:
    Acer XG270 Huomidpx
    CPU Cooler:
    Cooler Master Hyper 212 Evo
  • system
    PCHF Owner
    • 7695
    • CachyOS
    • Intel Arc A770 (16 GB)
    https://pcpartpicker.com/list/M7HqNQ
    Potential Issues / Incompatibilities
    [li]Some Intel B85 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.[/li][/ul]
    The incompatibility point isn’t an issue if you are successfully using your CPU with your motherboard already.
    Asus GeForce GTX 1080 Ti 11GB STRIX GAMING OC used for this compatibility test.
    • karciukas123456
      • Sep 2018
      • 7
      Originally posted by lkjk
      https://pcpartpicker.com/list/g2fxTB
      Thanks for quick reply. Let’s see if I got this right. So I need a new PSU because the one I got now doesn’t have 2x 8-pin connectors and this video card requires it. Right? In that case, could you recommend a decent one that has it and would actually fit in to my PC case? And the same with the video card it self, would it fit by dimensoins or does every manufacture have different dimensions on that card or any video card in generall?
      • system
        PCHF Owner
        • 7695
        • CachyOS
        I had used the CX750 instead of the CX750M for the original build. That issue is not relevant anymore.
        You can use the PCPartPicker site to try out different models of the 1080 Ti based on price, and see if it gives you any incompatibilities.
        New link:
        • karciukas123456
          • Sep 2018
          • 7
          Thank you
          New link:
          Thank you so much for your help!
            Excuse the interjection folks
            Upgrade the present PSU as well, the CX range of Corsair are only entry level or as Corsair put it here CX Series power supply units are an excellent choice for basic system builds and desktop PC computer upgrades.
            For high end GPUs never use a lower efficiency rated PSU than Gold, you want something like the EVGA here 12 year warranty if you purchase through Newegg or 10 years elsewhere.
              Any update for us?
