I recently noticed my i5-7500 runs at a speed of 3.6ghz when only using about 15% or 25%, i’m not sure why this is, my cpu has a base speed of 3.4ghz and a max turbo of 3.8ghz. (I also have enhanced intel speed step enabled and intel turbo boost) My question is should it be running this way, should i be worried or doesn’t it matter and i can just leave it?
i5-7500 running past base speed constantly
This topic is closed.
Excuse the interjection folks
Hello Ben,
Download CPU-Z (free) from here
Run CPU-Z then grab a screenshot of the results for us, please only use the method below for capturing and uploading the screenshot.
Click on the ALT key + PRT SCR key..its on the top row..right hand side..now click on start…all programs…accessories…paint…left click in the white area …press CTRL + V…click on file…click on save…save it to your desktop…name it something related to the screen your capturing… BE SURE TO SAVE IT AS A .JPG …otherwise it may be to big to upload… after typing in any response you have… click on Attach Files to add the screenshot.
Screenshot instructions are provided to assist those that may read this topic but are not yet aware of the “how to”.Comment
