Turn on desktop PC, fan sounds like car engine...
This topic is closed.
  • PcGuy34
    • Nov 2017
    • 96
    #16
    Originally posted by vger
    Any updates for us?
    Nope, still noisy for a few minutes, first time I start up my PC. Other times throughout the day/night start up is quiet.
      #17
      Any updates for us?
      • PcGuy34
        • Nov 2017
        • 96
        #18
        Any updates for us?
        No vger. Sorry guys. I really appreciate your help. I didn’t upgrade BIOS either. Guess I’ll wait til something goes kaput
          #19
          Not a good idea, for the sake of around $10 less if a chassis fan you may be risking serious hardware failure and possibly a fried processor.
          Can you post some hardware specs for us brand and model name or number of the case, MB, CPU and any add on video card if one is used, we could also do with knowing how many internal cooling fans there are apart from the CPUs and PSUs.
          • PcGuy34
            • Nov 2017
            • 96
            #20
            Originally posted by phillpower2
            Not a good idea, for the sake of around $10 less if a chassis fan you may be risking serious hardware failure and possibly a fried processor. Can you post some hardware specs for us brand and model name or number of the case, MB, CPU and any add on video card if one is used, we could also do with knowing how many internal cooling fans there are apart from the CPUs and PSUs.
            Antec DF-85 Black Steel / Plastic ATX Full Tower Computer Case (3 front fans, 2 rear fans, 2 top fans. All set on low. Optional side fan not installed)
            ASUS Z87-A LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
            Intel Core i5-4570 Haswell Quad-Core 3.2 GHz LGA 1150 84W BX80646I54570 Desktop Processor Intel HD Graphics
            SeaSonic X Series X650 Gold (SS-650KM Active PFC F3) 650W ATX12V V2.3/EPS 12V V2.91
            EVGA 02G-P4-3751-KR G-SYNC Support GeForce GTX 750 Ti 2GB 128-Bit GDDR5 PCI Express 3.0 Video Card
            I use to have a mobo that directly worked the case fans. I don’t believe my current mobo does that. That’s 1 reason I thought I might update the BIOS.
              #21
              Great case but not the best of installation manuals when it comes to the cooling fan connections, doesn`t say if the case fans all connect to the MB or direct to the PSU
              You should find the fan adjustment settings in the Advanced part of the BIOS but only of any use if the case fans are connected to the 4 pin fan headers on the MB.
              What I would suggest: with the computer disconnected from the power outlet, remove the side of the case, ground yourself by touching a bare metal part of the case/PSU, disconnect all of the case fans (leaving just the CPU/GPU cooling fans connected) reassemble and test, if all good power down, disconnect the power cord etc, ground yourself by touching a bare metal part of the case/PSU, connect only one of the case fans and the main power cord, power up and test, repeat the process until the problem fan has been identified.
              Must also consider that it cold b something else that is vibrating when cold and after getting warm expanding and the vibrating stopping, just another possibility to mention.
                #22
                Any update for us PcGuy34?
                  #23
                  Any update for us PcGuy34? If unreplied to within 48hrs this thread will be closed.
