Ok. I’ll check this tomorrow after work most likely. ???
PC help from BSOD crashes
I will have a reply for this thread tomorrow. But here is a guide I wrote to help with just that.
[EMBED content=“resource-245”]https://pchelpforum.net/r/how-to-optimize-your-windows-10-11-computer-for-gaming.245/[/EMBED]Comment
Let’s have a look with a different tool please.
Download ZHP Suite to your desktop.
Right Click Run as admin.
Hit the scanner button.
Once it is complete a file name ZHPdiag.txt will be on your desktop.
Attach it.
Uninstall Bonjour with GeekUninstaller.Code:Error: (08/07/2024 08:09:37 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: Local Hostname bggames.local already in use; will try bggames-2.local instead Error: (08/07/2024 08:09:37 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: ProbeCount 1; will deregister 16 bggames.local. AAAA FE80:0000:0000:0000:32E8:0A07:D82C:9A9E Error: (08/07/2024 08:09:37 PM) (Source: Bonjour Service) (EventID: 100) (User: ) Description: mDNSCoreReceiveResponse: Received from FE80:0000:0000:0000:32E8:0A07:D82C:9A9E:5353 16 bggames.local. AAAA 2603:9000:A300:327E:0000:0000:0000:1E62
I can also make a few suggestions on disabling some items from loading on your machine, should increase performance by freeing resources.
Download Autoruns and Autorunsc Unzip it to your desktop and then right click [IMG alt=“Capture.PNG”]https://pchelpforum.net/attachments/capture-png.9995/ Run as Admin.
After the scan is finished then click on File----Then click----Save
The default name will be autoruns.arn make sure to leave it this way.
Attach the file in your next reply.
If the file is too large, then use catbox.moe or Ufile.io and send the link in your next reply.[/IMG]Comment
here Upload files for free - BGGAMES.arn - ufile.io[/IMG][/QUOTE]Originally posted by MalnutritionI can also make a few suggestions on disabling some items from loading on your machine, should increase performance by freeing resources.
If the file is too large, then use catbox.moe or Ufile.io and send the link in your next reply.Comment
Right Click Autoruns, run as admin,.
Uncheck Everything in red pen, also type in one drive in the search box, uncheck everything related to onedrive. ( if you do not use)
Do the same for edge.
Also, block it if you are not using it.
[ATTACH type=“full” size=“1866x318”]14094[/ATTACH]
[ATTACH type=“full” size=“1832x261”]14095[/ATTACH]
[ATTACH type=“full” size=“1798x652”]14096[/ATTACH]
[ATTACH type=“full” size=“1754x184”]14097[/ATTACH]Comment
The update task and services are not really needed, they just use resources. You can update anything at anytime with this.
Patch My PC Home EditionComment
Search [COLOR=rgb(184, 49, 47)]onedrive here.
[ATTACH type=“full” alt=“1723169304008.png”]14098[/ATTACH][/COLOR]Comment
Onedrive removal Batch file:
