I think I might be infected, I'm not sure exactly of the symptoms and problems however.
  • skeller1
    • Feb 2024
    • 25
    #31
    I am getting many reports from eset saying can load ehdrv.sys?
    • Malnutrition
      PCHF Moderator
      • 7045
      #32
      You would need to disable defender and malwarebytes prior to scan
      • skeller1
        • Feb 2024
        • 25
        #33
        I found it, I needed to turn off memory integrity before the scan.
        • Malnutrition
          PCHF Moderator
          • 7045
          #34
          Ok. I have to work at 5 am. I will check this thread after work tomorrow. There is no rush to complete this. We will be here to help you.
          • skeller1
            • Feb 2024
            • 25
            #35
            Hey so I have a different question, I’m not sure if you are familiar with rawaccel, but at one point I used it and it left the driver behind. I used autoruns to try and disable it, but when I disabled it it prevented my mice from working?
            • Malnutrition
              PCHF Moderator
              • 7045
              #36
              OK, use everything search and delete everything you find related to rawaccel, just create a restore point first.
              • skeller1
                • Feb 2024
                • 25
                #37
                i mean I disabled it last time and it completely disabled all my mice, I don’t think that it is going to work?
                • Malnutrition
                  PCHF Moderator
                  • 7045
                  #38
                  Disable your Anitivirus/Defender prior to running.
                  [li]Unzip it there. – If you are unsure how to unzip a program, then use ---- http://www.7-zip.org/ ----[/li][li]Right click Autologger and run as admin. (Xp user double click)[/li][li]AVZ4 will open and scan your machine, allow this to complete.[/li][li]Upload Collectionlog.zip to your next reply.[/li][/ul]
                  • skeller1
                    • Feb 2024
                    • 25
                    #39
                    My ESET scan came up clean from last night.
                    • Malnutrition
                      PCHF Moderator
                      • 7045
                      #40
                      Ok, so there is nothing else then, I assume you are happy,.
                      • skeller1
                        • Feb 2024
                        • 25
                        #41
                        I am, but I am getting BSOD errors, not worried about malware - SYSTEM_SERVICE_EXCEPTION
                        • skeller1
                          • Feb 2024
                          • 25
                          #42
                          Most common when playing rainbow six seige but event viewer is showing many instances of errors
                          • skeller1
                            • Feb 2024
                            • 25
                            #43
                            Would you be the one to help?
                            • Malnutrition
                              PCHF Moderator
                              • 7045
                              #44
                              You know it could be due to the multiple leftovers of multiple Antivirus suites.
                              Ok upload your last two dump files.
                              • Malnutrition
                                PCHF Moderator
                                • 7045
                                #45
                                Or I can close this thread and mark solved since there is no malware and you can create a new thread here.
