Apparently this fixlog overwrote the one we did yesterday?? I ran it and it rebooted. I did a search on Everything and it only showed this one on the desktop. Hopefully it is the correct one.
Working with the Autologger now but cannot find Windows Defender to open and suspend it. It was on the desktop but not now. Did search on Everything for it but none of the files that came up will open Defender so…
Then open ccleaner hit tools then startup, then disable anything that you do not use on a daily basis. Then move onto scheduled task, you can disable pretty much everything there as well. Unless it relates to an antivirus or a program you need updated.
Then reboot.
After you post the autologger logs I’ll take a look when I get home.
I have uninstalled as much as I feel comfortable with. What about the software you had me download the last few days, and the reports, should I delete them now? Some of those I will keep, Do I need to keep CCleaner as one of the programs you had me download seems to do the same thing?
Take care of these items if possible. You can use the links provided or use Patch My Pc
Secunia PSI (2.0.0.3003) Warning! This software is no longer supported. Please uninstall it and use another software.
--------------------------- [ OtherUtilities ] ----------------------------
Microsoft .NET Framework 4.7.1 v.4.7.02558 Warning! Download Update
Microsoft Office 2000 Premium v.9.00.2720 Warning! This software is no longer supported. Please use latest Microsift Office, Office Online or LibreOffice
-------------------------------- [ Java ] ---------------------------------
JavaFX 2.1.1 v.2.1.1 Warning! This software is no longer supported. Please uninstall it and use Java SE 8 (jre-8u381-windows-i586.exe).
Java 7 Update 45 v.7.0.450 Warning! This software is no longer supported. Please uninstall it and use Java SE 8 (jre-8u381-windows-i586.exe).
-------------------------------- [ Media ] --------------------------------
QuickTime 7 v.7.79.80.95 Warning! This software is no longer supported. Please uninstall it and use another software.
Adobe AIR v.29.0.0.112 Warning! This software is no longer supported. Please uninstall it.
Adobe Media Player v.1.1 Warning! This software is no longer supported. Please uninstall it.
Adobe Acrobat Reader DC v.18.011.20063 Warning! Download Update ^Please run Acrobat Reader DC and go Help - Check for updates…[1]
Mozilla Firefox 57.0.2 (x86 en-US) v.57.0.2 Warning! Download Update
Glary Utilities 5.210 v.5.210.0.239 Warning! Suspected demo version of anti-spyware, driver updater or optimizer. If this program is not familiar to you it is recommended to uninstall it and execute PC scanning using Malwarebytes Anti-Malware. Possible you became a victim of fraud or social engineering. Computer experts no longer recommend this program.
Copy the content of the code box below.
[COLOR=rgb(184, 49, 47)]Do not copy the word code!!!
Right Click FRST and run as Administrator.
Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
Attach it to your next message.
Right click Run HijackThis! as admin! (located in the folder …Autologger\HijackThis)
Do a system scan, then check each item below, [COLOR=rgb(184, 49, 47)]make sure and only check the items listed.
Then click Fix checked.
The computer will need to reboot, allow it to do so.
When freeing up space a lot of people overlook the downloads folder. You can go to the location below and delete several unwanted items.
[ICODE]C:\Users\John\Downloads[/ICODE]
Also, what do you use this for?
[COLOR=rgb(184, 49, 47)]Remote Control USB Driver (HKLM-x32...{8471021C-F529-43DE-84DF-3612E10F58C4}) (Version: 2.3.2.317 - )
If not used by you anymore. I’d uninstall it.
Run… Easy Service Optimizer.
Download unzip to desktop, then select Tweaked mode and then hit the little rocket icon from within the program.
If you connect via wireless then you will need to enter the following commands in command prompt.
So you will need to enter these commands in Elevated Command prompt after running Easy Service Optimizer, if you so choose to run it.
Copy and paste each command one at a time and hit enter after.
sc start WlanSvc
sc config WlanSvc start= auto[/COLOR]
