i saw a thread on this website about this driver and it said it was malware but I do not understand the thread so i cant help myself. My wifi has been slow for quite a while and im making sure im not infected. Please help, once i clear this up i plan to go to network issues to resolve my wifi problems
\\?\Volume{95b0e598-5cef-289f-7c39-1efdc41a6154}\
Tags: None
Then you need to post following the instructions in the Malware removal section following the sticky threads.
Can you be infected just because that drive is showing no. I have several systems that show that type of drive due to the way my systems are configured. -
@Exo Starzs If you would post FRST logs then we can have this thread moved, no need to create a new one.
Once downloaded right click the FRST desktop icon and select “Run as administrator” from the menu"
FRST will open with two dialogue boxes, accept the disclaimer.
Then select Scan
Please Attach the contents of these logs in your next post for review by our Security TeamComment
i ended up completely restarting my pc since i hoped that restarting it would also help my network issuesOriginally posted by Malnutrition@Exo Starzs Any update?Comment
