100% CPU usage with IDM.
  • maxim123
    • Aug 2017
    • 472
    #16
    Hi, the kaspersky run seems to take a long time. I have stopped it to finish other works, will let it run overnight.
    • Malnutrition
      PCHF Moderator
      • 7041
      #17
      Copy the content of the code box below.
      [COLOR=rgb(184, 49, 47)]Do not copy the word code!!!
      Right Click FRST and run as Administrator.
      Click Fix once (!) and wait. The program will create a log file (Fixlog.txt).
      Attach it to your next message.
      Code:
      start::
      CreateRestorePoint:
      CloseProcesses:
      C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tencent Software
      C:\Users\Shahil\AppData\Roaming\Amazon
      DeleteKey: HKCU\SOFTWARE\Amazon
      DeleteKey: HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\Amazon
      DeleteKey: HKCU\SOFTWARE\3643b966-bc28-5bc8-95ff-3d47d66438db
      DeleteKey: HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\3643b966-bc28-5bc8-95ff-3d47d66438db
      DeleteKey: HKCU\SOFTWARE\nwjs
      DeleteKey: HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\nwjs
      DeleteKey: HKCU\SOFTWARE\T0
      DeleteKey: HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\T0
      C:\Users\Shahil\AppData\Local\Adaware
      C:\Users\Shahil\AppData\Local\Amazon
      C:\Users\Shahil\AppData\Local\nwjs
      C:\Users\Shahil\AppData\LocalLow\T0
      File: C:\Program Files (x86)\64BitMailAgent.exe
      File: C:\Program Files (x86)\SendCrashReport.exe
      File: C:\Program Files (x86)\TrackReview.exe
      C:\Windows\Temp\*.*
      C:\WINDOWS\system32\*.tmp
      C:\WINDOWS\syswow64\*.tmp
      emptytemp:
      Reboot:
      End::
      Download RogueKiller and install the program.
      Once downloaded and installed, right click and run as admin.
      Click the check for updates button.
      Go to scan setting then slide the MalPE option right to activate.
      Then go to scan, then start a full scan on your machine.
      Then click report when the scan completes.
      Under Share my report click on open then select text file.
      Copy it and paste the results here.
      Make sure you do not remove anything detected until I see the log please.
      Disable your Anitivirus/Defender prior to running.
      [li]Unzip it there. – If you are unsure how to unzip a program, then use ---- http://www.7-zip.org/ ----[/li][li]Right click Autologger and run as admin. (Xp user double click)[/li][li]AVZ4 will open and scan your machine, allow this to complete.[/li][li]Upload Collectionlog.zip to your next reply.[/li][/ul][/COLOR]
      • maxim123
        • Aug 2017
        • 472
        #18
        here are the KVRT logs
        it found 1 malicious program which I clicked delete. but the log files don’t have the recent scan. It only shows the log of yesterday’s incomplete scan.
        klr
        [ICODE]<Report> <Metadata Version="1" PCID="{FD210BA0-4E3C-341C-4615-CF142017925E}" LastModification="2023.09.30 18:41:33.685" /> <EventBlocks> <Block0 Type="Scan" Processed="312187" Found="0" Neutralized="0"> <Event0 Action="Scan" Time="133405506691873200" Object="" Info="Started" /> <Event1 Action="Scan" Time="133405521838387082" Object="" Info="Finished" /> </Block0> </EventBlocks> </Report> [/ICODE]
        klr. enc1 log
        [ICODE]咏姛€潧砚逑舷嫌泿嫀泿瞎姖渾€佉娃拖楷Λ彝敥捱呗郦墁萝坜圪挹卢┺圯咿刂葳獟拖湜媶墕寧泦€ 佉洼咻芰捱吝尴掭哲苷谮磷苒拖姥忮舷舷营檴仜瓋€寗溠忮舷舷舷舷迎儉寗呦粬煀彝紝巵拖繚€寠湝妺彝鬃拶蒉拖 ﹢殎嬕娃拖殯潕儐晩嬕娃脱忮舷舷舷舷舷舷营檴仜呦畬泦€佉图寧佂匣唫娨娃苘圻俎拶肿谪俎茇谕蠣崊妼浺屯夕 亯€彝紱帩泭嬐侠砚逑舷舷舷舷舷嫌獧妬涋袭寷唨佉瞳姏妼浲匣唫娨娃苘圻俎谵刂葚众纵谕蠣崊妼浺同粘竼亱€槣 臣枩泭傑莩紵煪棝瑎偁崊€劻媰兺夕亯€彝寗粈€兞竼佡哿あ籍殯€翈屚侠砚逑舷舷舷舷舷嫌獧妬涊袭寷唨佉 图寧佂匣唫娨娃苘圻俎谥字周捃拶弁蠣崊妼浺屯夕亯€彝﹩亞渿妺拖姥忮舷舷舷舷舷舷营檴仜芟畬泦€佉图妰妼浵 帉泦€佂匣唫娨娃苘圻俎仝葙挹僮挹尥蠣崊妼浺同粘竼亱€槣臣枩泭傑莩紵煪棝瑎偁崊€劻媰兺夕亯€彝珚儕泭 拖姥忮舷舷舷舷舷舷营檴仜巯畬泦€佉瞳啘唩墛寷唨佂匣唫娨娃苘圻俎仝葙挹僮挹尥蠣崊妼浺屯夕亯€彝紱帩泭嬐 侠砚逑舷舷舷舷舷嫌獧妬涄袭寷唨佉途殠潕仜唩妺拖粏倞彝捃苒哔拶谳俎谥走儋拖爫厞寷彝掣唩媭槣臣枩泭傑莩 紵煪棝瑎偁崊€劻媰兺夕亯€彝拖姥忮舷舷舷舷舷舷营檴仜傧畬泦€佉瞳妰姏妺拖粏倞彝捃苒哔拶谳俎谥走儋拖 爫厞寷彝掣唩媭槣臣枩泭傑莩紵煪棝瑎偁崊€劻媰兺夕亯€彝拖姥忮舷舷舷舷舷舷营檴仜叵畬泦€佉瞳啘唩墛 寷唨佂匣唫娨娃苘圻俎仝葙坜众棕赝蠣崊妼浺屯夕亯€彝﹩亞渿妺拖姥忮舷舷舷舷永瓋€寗哐忮舷舷永獧妬洯儉寗 溠忮永綂焵潧砚?[/ICODE]
        • maxim123
          • Aug 2017
          • 472
          #19
          klr
          klr. enc1 log
          • maxim123
            • Aug 2017
            • 472
            #20
            I opened KVRT, and had found the report of the recent scan, but mistakenly deleted it while clicking right click on it.
            [ATTACH type=“full”]12736[/ATTACH]
            • maxim123
              • Aug 2017
              • 472
              #21
              Fixlog
              [HEADING=1]
              Code:
              Fix result of Farbar Recovery Scan Tool (x64) Version: 25-09-2023
              Ran by Shahil (01-10-2023 12:48:03) Run:2
              Running from C:\Users\Shahil\Desktop
              Loaded Profiles: Shahil
              Boot Mode: Normal[/HEADING]
              fixlist content:
              [HR][/HR]
              start::
              CreateRestorePoint:
              CloseProcesses:
              C:\Windows\Temp*.*
              C:\WINDOWS\system32*.tmp
              C:\WINDOWS\syswow64*.tmp
              emptytemp:
              Reboot:
              End::
              [HR][/HR]
              “C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tencent Software” folder move:
              C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tencent Software => moved successfully
              “C:\Users\Shahil\AppData\Roaming\Amazon” folder move:
              C:\Users\Shahil\AppData\Roaming\Amazon => moved successfully
              HKCU\SOFTWARE\Amazon => removed successfully
              HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\Amazon => not found
              HKCU\SOFTWARE\3643b966-bc28-5bc8-95ff-3d47d66438db => removed successfully
              HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\3643b966-bc28-5bc8-95ff-3d47d66438db => not found
              HKCU\SOFTWARE\nwjs => removed successfully
              HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\nwjs => not found
              HKCU\SOFTWARE\T0 => removed successfully
              HKU\S-1-5-21-4291915333-2200026273-1243826419-1001\SOFTWARE\T0 => not found
              “C:\Users\Shahil\AppData\Local\Adaware” folder move:
              C:\Users\Shahil\AppData\Local\Adaware => moved successfully
              “C:\Users\Shahil\AppData\Local\Amazon” folder move:
              C:\Users\Shahil\AppData\Local\Amazon => moved successfully
              “C:\Users\Shahil\AppData\Local\nwjs” folder move:
              C:\Users\Shahil\AppData\Local\nwjs => moved successfully
              “C:\Users\Shahil\AppData\LocalLow\T0” folder move:
              C:\Users\Shahil\AppData\LocalLow\T0 => moved successfully
              ========================= File: C:\Program Files (x86)\64BitMailAgent.exe ========================
              File is digitally signed
              MD5: FA53099C5BE9982A58B41B888C2B35B6
              Creation and modification date: 2021-05-06 11:07 - 2021-03-18 20:43
              Attributes: ----A
              Company Name: FOXIT SOFTWARE INC. → Foxit Software Inc.
              Internal Name: Courier.exe
              Original Name: Courier.exe
              Product:
              Description: 64Bit MAPI Mail Agent
              File Version: 1.0.8.1228
              Product Version: 1.0.8.1228
              Copyright: Copyright © 2014-2020 Foxit Software Inc. All Rights Reserved.
              VirusTotal: VirusTotal
              ====== End of File: ======
              ========================= File: C:\Program Files (x86)\SendCrashReport.exe ========================
              MD5: 0D83B827BE2277A438DF1074A7385738
              Creation and modification date: 2021-05-06 11:07 - 2021-04-12 02:01
              Attributes: ----A
              Company Name: FOXIT SOFTWARE INC. → Foxit Corporation
              Internal Name: SendCrashReport
              Original Name: SendCrashReport.exe
              Product: SendCrashReport
              Description: SendCrashReport
              File Version: 10.1.0.924
              Product Version: 10.1.0.924
              Copyright: Copyright © 2013-2020 Foxit Software Inc. All Rights Reserved.
              ========================= File: C:\Program Files (x86)\TrackReview.exe ========================
              MD5: CD7CF4BCC61AE27A64B5EC1B2AEAD939
              Creation and modification date: 2021-05-06 11:07 - 2021-04-12 02:02
              Attributes: ----A
              Internal Name: TrackReview.exe
              Original Name: Foxit Track Review
              Product: Foxit Track Review
              Description: Track Review
              File Version: 10.1.4.37623
              Product Version: 10.1.4.37623
              =========== “C:\Windows\Temp*.*” ==========
              C:\Windows\Temp\DESKTOP-AKRBR60-20230930-1730.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20230930-1735.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20230930-1757.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-0310.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1043.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1046.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1046a.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1048.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1225.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1235.log => moved successfully
              C:\Windows\Temp\DESKTOP-AKRBR60-20231001-1240.log => moved successfully
              C:\Windows\Temp\MpCmdRun.log => moved successfully
              C:\Windows\Temp\MpSigStub.log => moved successfully
              ========= End → “C:\Windows\Temp*.*” ========
              =========== “C:\WINDOWS\system32*.tmp” ==========
              not found
              ========= End → “C:\WINDOWS\system32*.tmp” ========
              =========== “C:\WINDOWS\syswow64*.tmp” ==========
              not found
              ========= End → “C:\WINDOWS\syswow64*.tmp” ========
              FlushDNS => completed
              BITS transfer queue => 786432 B
              DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 13897223 B
              Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 81492760 B
              Windows/system/drivers => 0 B
              Edge => 0 B
              Chrome => 0 B
              Firefox => 1143487641 B
              Opera => 0 B
              Default => 0 B
              ProgramData => 0 B
              Public => 0 B
              systemprofile => 0 B
              systemprofile32 => 0 B
              LocalService => 0 B
              NetworkService => 0 B
              Shahil => 1949632 B
              RecycleBin => 0 B
              EmptyTemp: => 1.2 GB temporary data Removed.
              The system needed a reboot.
              ==== End of Fixlog 12:48:51 ====
              [/HEADING]
              • maxim123
                • Aug 2017
                • 472
                #22
                Hi, I have to go out rn for some work, will scan with rogue killer and antilogger after I return.
                • maxim123
                  • Aug 2017
                  • 472
                  #23
                  Rogue killer log
                  Code:
                  Program : RogueKiller Anti-Malware
                  Version : 15.12.1.0
                  x64 : Yes
                  Program Date : Sep 18 2023
                  Location : C:\Program Files\RogueKiller\RogueKiller64.exe
                  Premium : No
                  Company : Adlice Software
                  Website : https://www.adlice.com/
                  Contact : Support Form | Contact • Adlice Software
                  Website : Free Virus Cleaner | RogueKiller AntiMalware • Adlice Software
                  Operating System : Windows 10 (10.0.19045) 64-bit
                  64-bit OS : Yes
                  Startup : 0
                  WindowsPE : No
                  User : Shahil
                  User is Admin : Yes
                  Date : 2023/10/01 10:05:46
                  Type : Scan
                  Aborted : No
                  Scan Mode : Standard
                  Duration : 613
                  Found items : 1
                  Total scanned : 113265
                  Signatures Version : 20230928_070539
                  Truesight Driver : Yes
                  Updates Count : 9
                  Arguments : -minimize
                  ************************* Warnings *************************
                  ************************* Updates *************************
                  7-Zip 22.01 (x64) (64-bit), version 22.01
                  [+] Available Version : 23.01
                  [+] Size : 5.46 MB
                  [+] Wow6432 : No
                  [+] Portable : No
                  [+] update_location : C:\Program Files\7-Zip\
                  AutoHotkey 1.1.33.10 (64-bit), version 1.1.33.10
                  [+] Available Version : 2.0.10
                  [+] Wow6432 : No
                  [+] Portable : No
                  Subtitle Edit 3.6.0 (64-bit), version 3.6.0.0
                  [+] Available Version : 4.0.1.0
                  [+] Size : 27.2 MB
                  [+] Wow6432 : No
                  [+] Portable : No
                  [+] update_location : d:\Program Files\Subtitle Edit\
                  Malwarebytes version 4.5.21.231 (64-bit), version 4.5.21.231
                  [+] Available Version : 4.6.3
                  [+] Wow6432 : No
                  [+] Portable : No
                  [+] update_location : C:\Program Files\Malwarebytes\Anti-Malware
                  calibre 64bit (64-bit), version 5.20.0
                  [+] Available Version : 6.27.0
                  [+] Size : 355 MB
                  [+] Wow6432 : No
                  [+] Portable : No
                  [+] update_location : C:\Program Files\Calibre2\
                  FormatFactory 4.3.0.0 (32-bit), version 4.3.0.0
                  [+] Available Version : 5.15.0.0
                  [+] Wow6432 : Yes
                  [+] Portable : No
                  OBS Studio (32-bit), version 28.0.3
                  [+] Available Version : 29.1.3
                  [+] Wow6432 : Yes
                  [+] Portable : No
                  qBittorrent 4.4.0 (32-bit), version 4.4.0
                  [+] Available Version : 4.5.5
                  [+] Size : 163 MB
                  [+] Wow6432 : Yes
                  [+] Portable : No
                  VLC media player (32-bit), version 2.2.0
                  [+] Available Version : 3.0.18
                  [+] Wow6432 : Yes
                  [+] Portable : No
                  [+] update_location : C:\Program Files (x86)\VideoLAN\VLC
                  ************************* Processes *************************
                  ************************* Modules *************************
                  ************************* Services *************************
                  ************************* Scheduled Tasks *************************
                  ************************* Registry *************************
                  ************************* WMI *************************
                  ************************* Hosts File *************************
                  is_too_big : No
                  hosts_file_path : C:\Windows\System32\drivers\etc\hosts
                  ************************* Filesystem *************************
                  [Cloud.Generic (Malicious)] (file) msimg32.dll – C:\Users\Shahil\AppData\Roaming\MetaQuotes\Terminal\2191F4A3D14D7B4B1EBB84F924777883\MQL4\Indicators\msimg32.dll → Found
                  ************************* Web Browsers *************************
                  ************************* Antirootkit *************************
                  • maxim123
                    • Aug 2017
                    • 472
                    #24
                    Hi, here is the collection log of autologger.
                    • Malnutrition
                      PCHF Moderator
                      • 7041
                      #25
                      I will check these when I get home today.
                      • Malnutrition
                        PCHF Moderator
                        • 7041
                        #26
                        Run HijackThis! as admin! (located in the folder …Autologger\HijackThis)
                        Do a system scan, then check each item below, make sure and only check the items listed.
                        Then click Fix checked.
                        The computer will need to reboot, allow it to do so.
                        Code:
                        O22 - Task: (damaged) HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\MEGA (empty)
                        O22 - Tasks: (damaged) \Microsoft\Windows\Application Experience\MareBackup - C:\WINDOWS\system32\compattelrunner.exe -m:aemarebackup.dll -f:BackupMareData (user missing) (sign: 'Microsoft')
                        O22 - Tasks: (damaged) \Microsoft\Windows\Application Experience\MareBackup - C:\WINDOWS\system32\compattelrunner.exe -m:appraiser.dll -f:DoScheduledTelemetryRun (user missing) (sign: 'Microsoft')
                        O23 - Driver R: (no name) - C:\WINDOWS\System32\drivers\dump_iaStorAVC.sys (file missing)
                        Look in the Autologger folder and drag out the CheckBrowsersLNK file.
                        To your desktop.
                        AutoLogger\CheckBrowserLnk
                        Drag and drop onto the ClearLNK utility .
                        After saving ClearLNK to desktop.
                        [IMG alt=“move.gif”]https://dragokas.com/tools/move.gif[/IMG]
                        • Malnutrition
                          PCHF Moderator
                          • 7041
                          #27
                          Any more issues to speak of?
                          • maxim123
                            • Aug 2017
                            • 472
                            #28
                            Hi,
                            [ATTACH type=“full”]12745[/ATTACH]
                            there is no CheckBrowsersLNK text file.
                            I moved the debug to Clear LNK and it says no shortcuts here or files don’t exist message. and then it gives error saying
                            [ATTACH type=“full”]12746[/ATTACH]
                            • maxim123
                              • Aug 2017
                              • 472
                              #29
                              There are no more issues. Thank you so much.
                              • Malnutrition
                                PCHF Moderator
                                • 7041
                                #30
                                I have uploaded the text file for you.
                                Here, drag and drop this text file onto.
                                So the machine is running well and no more issues. I’ll mark as solved.
                                We will clean all the tools we used…
                                Download KpRM
                                Save to Desktop
                                Check Delete Tools’
                                Check Delete Restore points.
                                Create Restore point.
                                Click delete quarantines.
                                Then click run.
                                I suggest:
                                Ublock Origin
                                O&O Shutup Ten
                                O&O App Buster[/IMG]
